I could use some good advice on a tough finish spec. I am rebuilding some old saltwater fishing rods. They have the old style long wooden handles. I am looking for the best way to finish. The rods will see salt water, get regular fresh water rinses, and a fair amount of the outdoors. A heavy poly? Maybe an annual soaking of oil? Any and all advice is VERY appreciated!
I'd go for an epoxy finish. completely seals the wood against sand, salt and water. Sand would abrade the wood, salt would dry out the wood, any splashes would leave standing water that causes splits and discolouration. Take no chances with any of that stuff.
Maybe cut it with CA glue to make it super resiliant?
if you don't like the shiny finish, just grind some chalk into a bowl of soapy water and rub to a satin finish
Just use spar varnish, a couple of coats should work well. Spar varnish has UV inhibitors in it and is designed for outdoor use exactly like the fishing rod handles will see. Simple and works well.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
