Hey cribbage board builders..........
Forum topic by redryder posted 09-07-2013 09:38 PM 2809 views 0 times favorited 7 replies Add to Favorites Watch
View redryder's profile
redryder
2393 posts in 3067 days
09-07-2013 09:38 PM
Topic tags/keywords: question finishing
I just purchased a great looking set of XL cribbage board templates and pins from Rockler.
I would like to make a couple of boards for Christmas presents.
My questions are: (1) Should I finish the wood before I drill the holes or after and (2) If I finish the wood after I drill the holes, should I use spray to keep it light or is brush on O.K. I would like to not screw this up particularly after drilling more than a hundred holes.
Thanks in advance, mike….......................
-- mike...............
7 replies so far
View teejk's profile
teejk
1215 posts in 2650 days
#1 posted 09-07-2013 09:50 PM
wow…didn’t know many people played one of my favorite games anymore (did you get a “derby” layout)?
Anyway, I think finishing after the fact might fill the holes (but you some wiggle room on the pegs). Prefinishing I think you will mar the finish in the drilling operations. So maybe split the difference?
BTW a group of old guys I know play on a huge board…pegs are spent 30-06 casings…the holes are cut with a plug cutter!!!
View Joe Lyddon's profile
Joe Lyddon
10048 posts in 4018 days
#2 posted 09-07-2013 10:01 PM
I don’t think it makes a huge difference…
If you’re going to glue hole liners into the holes, might be better to Finish First then drill using a Bradpoint bit…
Use a drill press with a fence setup to help hit the centers.
I print the layout off the computer & tape to the board, tapped centers with a nail punch, etc. with a good impression.
Make sure it’s right before you start punching it… make sure it’s taped good.
When I made some (2), One was drilled before Finishing and One was Finished first then drilled… Both had hole liners and both turned out OK!
teejk
#3 posted 09-07-2013 11:04 PM
Joe…did you do the traditional “up/bacK” on your boards? It is a Pub-game after all and most people forget which direction they are heading after making the turns.
Joe Lyddon
#4 posted 09-09-2013 05:06 AM
I just used the pattern like a picture the customer wanted…
... used the computer to lay it out…
... Printed it out & used it.
View laketrout36's profile
laketrout36
200 posts in 1992 days
#5 posted 09-12-2013 02:17 AM
I drilled all the holes and then wiped on the stain. It worked great. Keep in mind because of the holes you’ll have to increase your drying time. I probably used to much on my board but it turned out good and time wasn’t an issue for me. I noticed the Wenge and Sapele seemed to expel some of the stain for a couple of days after the application. Maybe thats called saturation.
View Dusty56's profile
Dusty56
11819 posts in 3653 days
#6 posted 09-12-2013 03:26 AM
You stained Wenge and Sapele ??? What color(s) ?
laketrout36
#7 posted 09-12-2013 11:49 AM
Minwax natural.
