Using upcut or down cut bits?
Forum topic by MrRon posted 09-06-2013 09:42 PM 944 views 0 times favorited 2 replies Add to Favorites Watch
View MrRon's profile
MrRon
4718 posts in 3210 days
09-06-2013 09:42 PM
When routing with a hand held router, you use an upcut bit when the cut doesn’t go all the way through the material and a downcut bit when going all the way through. Is that correct?
When using the router in a router table, which bit do you use; up or down cut? It would appear that either one will work?
2 replies so far
10268 posts in 3614 days
#1 posted 09-06-2013 09:48 PM
Upcut bits pull the chips out of a mortise, so generally
for mortising and grooving cuts they work well.
I use a downcut bit on my overarm router because
it pushes the work away from the cutter. The upcut
bit is unsafe in this application (no base plate on a pin
router) because it will lift the work off the table.
View GarageWoodworks's profile
GarageWoodworks
531 posts in 2123 days
#2 posted 09-06-2013 09:53 PM
Upcut pulls chips out as mentioned above and are more prone to chip-out at the top of the mortise.
Downcut bits leave a much cleaner cut at the top which makes them ideal for doing inlay.
-- Subscribe on YouTube: http://www.youtube.com/user/GarageWoodworks?feature=guide
