Advice on other methods of cutting a profile
Forum topic by Woodendeavor posted 09-05-2013 08:17 PM 765 views 0 times favorited 5 replies Add to Favorites Watch
View Woodendeavor's profile
Woodendeavor
276 posts in 2569 days
09-05-2013 08:17 PM
I am trying to incorporate an inverted glass holder on the end of a wine shelf. I have made one shelf as a prototype but do not want to do that again.
This was made by pushing the board into a raised panel cutter to a stop block and then pulled straight back. The cut gets allot of chatter and I need to find a better way to build it. Any thoughts you may have would be great. Here is a picture of the profile, I want to keep the profile the same as you see here
Thanks in advance for any suggestions
5 replies so far
View pintodeluxe's profile
pintodeluxe
5618 posts in 2776 days
#1 posted 09-05-2013 08:20 PM
I like your method, just cut it in multiple passes. Adjust the depth of cut until you have it right.
Scraps of wood clamped to your shaper table can act as guides to keep the workpiece tracking straight. They work like featherboards, but you can pull the workpiece back out without binding.
Woodendeavor
#2 posted 09-05-2013 08:24 PM
Willie,
That is how this was milled and I was taking about 1/32” per pass. It still wants to grab and tear out the grain when the bit is trying to cut the full half circle
pintodeluxe
#3 posted 09-05-2013 08:37 PM
Hmm, that’s surprising. If the bit was sharp, and the wood wasn’t a particularly wild grain it seems like a viable method. Maybe it chatters because it is trying to cut both sides of the profile at once. Can you turn the speed down on the shaper?
Don’t do it if it feels unsafe.
Good luck
Woodendeavor
#4 posted 09-05-2013 09:07 PM
I fell very safe, guides on both sides and a hod down over the cutter in a 3hp router table I am just having a hard time getting a smooth cut. I have tried playing with the speed a little bit but no help there. It is in the last 1/4 inch of push before I hit my stop block that the cutter jerks the board forward tearing out some grain as it goes. The wood you see pictured is quarter sawn sycamore so it is not that hard. I thought it would work easily as I would like to produce some of my design for this holiday season but it looks like back to the drawing board for me
View jte9999's profile
jte9999
25 posts in 2064 days
#5 posted 09-05-2013 09:59 PM
It looks to me like a chip clearance problem in the last portion of the cut. Perhaps you could cut the through groove first with a straight bit and then cut the profile in multiple 1/32” passes. Maybe??? Hope this helps.
—jay
-- --half full, half empty? How about twice as big as it needs to be?
