Saw blade for bamboo ply?
Forum topic by Jackietreehorn posted 09-05-2013 07:53 PM 2273 views 0 times favorited 5 replies Add to Favorites Watch
View Jackietreehorn's profile
Jackietreehorn
150 posts in 2057 days
09-05-2013 07:53 PM
Topic tags/keywords: bamboo plywood
Hope this right area to ask, I want to get a new blade before I start next project and am curious what blades have worked well with bamboo ply.
Thanks in advance!
-- www.nobleprojects.blogspot.com
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2808 days
#1 posted 09-06-2013 01:27 AM
I use a 40 tooth Freud Diablo and get very clean cuts BUT I always use a zero clearance insert.
View Loren's profile
10477 posts in 3766 days
#2 posted 09-06-2013 01:32 AM
It’s splintery so a blade suited for fine crosscuts or melamine
will give the the cleanest cut. A zero clearance insert, properly
set up so there is no gap between the insert and the
work when feeding (check saw table flatness, etc) is
a cheaper way to use a less-than-premium blade. If
you check the prices on melamine blades you’ll see what
I mean.
gfadvm
#3 posted 09-06-2013 01:49 AM
I have noticed that “Tiger Strand” bamboo splinters MUCH worse than conventional (non-stranded) bamboo ply.
Taping the cutline with blue painter’s tape does NOT seem to help much when crosscutting stranded bamboo.
Jackietreehorn
#4 posted 09-06-2013 02:27 PM
Got it! My last project involved melamine and instead of using a melamine blade I used a thin kerf 80 tooth blade I had with zero clearance insert. It actually worked out better than the melamine blade I had used in my other shop. Thanks for the input!
View knotscott's profile
knotscott
8121 posts in 3494 days
#5 posted 09-06-2013 09:32 PM
A blade with a high tooth and a Hi-ATB grind will give the least amount of tearout. Infinity makes some of the best blades I’ve used….their Ultrasmooth 010-080 would be ideal, but their 010-060 would also be a great choice. A Forrest Duraline, Freud LU79/LU80, or CMT 210.080.10 would also be fine choices. One of those blades and the technique suggest by gfadvm should give you great results.
