Band Saw Tuning / Blade Question
Forum topic by RPhillips posted 09-05-2013 03:49 AM 1236 views 0 times favorited 8 replies Add to Favorites Watch
View RPhillips's profile
RPhillips
1180 posts in 1836 days
09-05-2013 03:49 AM
I recently purchased a Craftsman 14” band saw (Rikon Clone) and I noticed after installing my new Wood Slicer 3t x 3/8” Re-Sawing blade that it wants to move a lot on the wheels and you could see the movement between the thrust bearing too, but not as much since the thrust bearings guide it. The movement is from front to back, and it did seem to get a little better after fully tensioning the blade and allowing it to run for a few mins.
Is this normal? I believe I got the machine set up fairly well and my other blade (OEM) doesn’t do this.
Defective blade or is it just set up? It cuts great, but I’m no expert on band saws, so I thought I’d come here for some support.
Thanks
-Rob
-- Rob - Indianapolis IN - Learning... one mistake at a time...
8 replies so far
View lumbermeister's profile
lumbermeister
128 posts in 1979 days
#1 posted 09-05-2013 04:36 PM
Are you certain that you have the blade fully tensioned? Even though it may indicate so on the saw’s built-in tension indicator (if this is the Craftsman BAS350, I have the same saw), blades vary in length beyond their indicated length.
You might give this video a look – from a guy from Carter Products. He has quite a few good tips on setting up a bandsaw, including blade tensioning.
http://www.youtube.com/watch?v=wGbZqWac0jU
RPhillips
#2 posted 09-05-2013 05:32 PM
thanks for the link, checking it out now…
I think I have the tension set correctly, but in all honesty I can’t say for sure.
View gfadvm's profile
gfadvm
14940 posts in 2690 days
#3 posted 09-06-2013 01:18 AM
I always “stone” the back side of my blades to ensure that the weld is flat and smooth as this can result in what you describe as well as premature blade breakage.
View MrRon's profile
MrRon
4770 posts in 3243 days
#4 posted 09-06-2013 07:27 PM
Check my thread of 3 days ago titled “To all Band saw owners”
View HorizontalMike's profile
HorizontalMike
7757 posts in 2914 days
#5 posted 09-06-2013 07:49 PM
gfadvm: ”...I always “stone” the back side of my blades…”
+10 on THAT. My first 111in TW 3TPI blade had a decided bump at the weld that stretched out on either side of the weld about 3in or so. I stoned it to minimize that bump/rise and used this blade for ~3yr. During that time I noticed that the thrust bearing would/had mushroomed the back of the blade to where it would catch on your fingernail. Restoned it again,... and later again as well. The point is, the thrust bearing will wear and mushroom the back of the blade over time, depending on how much you use it, how much width you resaw, etc.
And after 3yr I replaced all bearings for less than $20 and have enough spare new bearings to do replace all again in the future. I also lubricate the sides of the blade frequently, with either PAM or PB-Blaster. It makes quite a difference in your cut. My 2-cents. I now use the 111in TW 2-3TPI which is even better for large resawing.
RPhillips
#6 posted 09-07-2013 09:21 AM
I set it up again using the carter method and it seems to be a little better. Thanks for the input guys…still learning so much…and still so much to learn.
View Loco's profile
Loco
210 posts in 1749 days
#7 posted 09-07-2013 12:23 PM
You sure the Rikon isn’t a Craftsman clone ?
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
RPhillips
#8 posted 09-08-2013 12:16 AM
actually, no I ‘m not sure…. BUT considering Sears/Craftsman actually doesn’t make anything of their own anymore, I’d be willing to chance it…
