Planer motor running erratically, Bad Brushes?
Forum topic by Blackie_ posted 09-04-2013 10:39 PM 1248 views 0 times favorited 11 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4843 posts in 2386 days
09-04-2013 10:39 PM
I have the Ryobi AP 1301 have had it for several years, just a couple days ago I noticed the motor starting fluctuating, pulsating, losing power gaining power running erratically, acting like it’s trying to go out, so I’m wondering if brushes going bad can cause this?
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
11 replies so far
View crank49's profile
crank49
4028 posts in 2844 days
#1 posted 09-04-2013 11:25 PM
Yes, it is possible for bad brushes to cause the problem you described.
Unplug the planer, and then unscrew one of the brush retainers, then pull out and inspect one of the brushes.
Then check the other side. It is not hard to do.
View Jim Jakosh's profile
Jim Jakosh
19957 posts in 2979 days
#2 posted 09-04-2013 11:43 PM
Check the brushes. what happens is build up of dirt and carbon at the end which holds them away from the armature just a bit and then they arc and soon quit if not cleaned out.
LJ Rustic had that happen to his HF lathe and Craftsman table saw last week!
HillbillyShooter
5811 posts in 2165 days
#3 posted 09-04-2013 11:45 PM
Agree with Jim J. Also, make sure the brushes are not burned too short.
View DocSavage45's profile
DocSavage45
8430 posts in 2716 days
#4 posted 09-05-2013 12:05 AM
If that’s not the fix then bearings, belts, and starting capacitor? Step at a time.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Roger's profile
Roger
20897 posts in 2677 days
#5 posted 09-05-2013 01:54 AM
Good luck with the fix
Blackie_
#6 posted 09-05-2013 02:30 AM
I ordered the brushes lets hope they fix the problem, thanks for the replies and the help all.
crank49
#7 posted 09-05-2013 02:40 AM
That saw has a universal, series wound motor, so there is no starting or running capacitor.
Blackie_
#8 posted 09-09-2013 04:38 PM
Set of new brushes fixed the problem, thanks again all.
View Tim's profile
Tim
3707 posts in 1834 days
#9 posted 09-09-2013 06:04 PM
Did you save the old ones? I don’t know anything about this motor, but sometimes it’s just a matter of the end of the brushes having uneven wear and they don’t contact enough. You can take the old ones out and if there’s still enough material, even out/flatten the contact end and reinstall and they will work better.
Blackie_
#10 posted 09-09-2013 10:49 PM
Tim I compared the old with the new ones and that was quite a bit of difference in ware, I’ve already thrown them away.
crank49
#11 posted 09-10-2013 05:22 PM
It’s good to run those new brushes for a while with no load on them. Gives them a chance to conform to the shape of the armature.
