Glueline rips w/ Freud LU83R10 possible?
Forum topic by savan posted 09-04-2013 02:05 AM 1071 views 0 times favorited 6 replies Add to Favorites Watch
View savan's profile
savan
97 posts in 2268 days
09-04-2013 02:05 AM
are any of you all getting glue line rips w/ the Freud Industrial 50T Combi (LU83R10)?
I got a new to me saw and have roughly checked the blade alignment. It seemed pretty good. I know that’s vague.
I switched to the 50T because it has the flat tooth whereas the 40T i was using was an ATB and left messy dados. I thought going to 50T was going to yield even better rips that I was getting w/ the 40T but as of right now that’s not the case. I’m getting very evident tooth marks.
I’ve yet to put a dial to the blade and mitre slot but my adjustable square said it was pretty close to dead on.
I’ll check alignment further but wanted to get a consensus on performance of the LU83R10.
Thanks!
View BArnold's profile
BArnold
175 posts in 1709 days
#1 posted 09-04-2013 02:14 AM
I can’t speak to the specific blade you mentioned, but I definitely get good edges for gluing with my Freud LM74R GLR blade.
-- Bill, Thomasville, GA
View HorizontalMike's profile
HorizontalMike
7736 posts in 2790 days
#2 posted 09-04-2013 02:19 AM
I use the full kerf version of that blade and am satisfied with its performance.
That said, I usually prefer leaving my Freud LM72M010 Industrial Heavy Duty Rip Saw Blade 10-Inch by 24t Flat Top 5/8-Inch arbor Ice Coated on the TS. And I usually get glue line rips with this blade as well.
View jusfine's profile
jusfine
2422 posts in 2802 days
#3 posted 09-04-2013 02:26 AM
I have used a number of their LU blades, never got a glue line rip, so switched to Forrest. Incredible difference.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View knotscott's profile
knotscott
7822 posts in 3252 days
#4 posted 09-04-2013 09:21 AM
It’s definitely possible to get glue line edges with the LU83 (and other good 50T combo blades), though due that flat raker the 50T ATB/R blades tend to have more pronounced blade marks than the better examples of 40T general purpose blades. If the saw is dialed in, the marks shouldn’t interfere with a glue line edge….so long as it’s not severely rough, it doesn’t have to be literally glass smooth for glue up. Like Mike, I’ve gotten glue ready edges from a number of decent 24T rip blades too.
HorizontalMike
#5 posted 09-04-2013 10:47 PM
One thing I forgot to mention above is just how well that 24T blade does with dados and rabbets… none better. And yeah, I’m lazy and don’t use a dado blade set, as I just nibble away and get my best fit for my under/over sized width boards depending on project. Remember… wood talks to you and you need to listen or you will surely make larger mistakes… ;-)
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1949 days
#6 posted 09-04-2013 11:28 PM
I’m in the forrest camp. Freud’s go on the chop saws in my world. IMHO.
-- Who is John Galt?
