type of air compressor and paint gun needed?
Forum topic by thatlabguy posted 09-03-2013 11:00 PM 1459 views 0 times favorited 6 replies Add to Favorites Watch
View thatlabguy's profile
87 posts in 2625 days
09-03-2013 11:00 PM
I am getting ready to purchase what I will need to be able to use pre-cat finish on my dining tables, etc. My question is what specs should the air compressor have and recommendations of paint guns for the best finish results.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2464 days
#1 posted 09-04-2013 12:48 AM
I’ll ask the obvious question first – what is your budget? You can spend a little money or a lot of money…
If you don’t already have a compressor, and don’t have a need for a compressor outside of spraying finishes, your best bet is a self-contained HVLP unit, which is a gun and air supply unit designed to work together. HVLP units are quite portable so you can set up and spray pretty much anywhere.
To spray larger pieces with a compressor and gun combo, you are usually looking at a mid-size stationary compressor. Even the largest portable compressor (around 30 gallon tank) is barely adequate for anything but small pieces. And don’t even think about using your typical construction site hotdogs or pancakes. The advantage to going the compressor route is that you can switch guns easily and have different guns for different tasks. The disadvantage is that you are tied to your compressor.
-- Mark Kornell, Kornell Wood Design
View cutworm's profile
1075 posts in 2726 days
#2 posted 09-04-2013 01:15 AM
Good question. I’m not an authority but pre-cat is a good choice. I have sprayed it with my Harbor Freight HVLP turbine and with my compressed air sprayer. It does require a bit of practice so be patient. It helps to keep a log of finish/thinner ratios, pressure settings, nozzle sizes, etc. Hope it turns out well.
-- Steve - "Never Give Up"
View Clint Searl's profile
Clint Searl
1533 posts in 2294 days
#3 posted 09-04-2013 01:26 AM
SATA or Devilbiss gravity feed gun and the biggest compressor you can afford.
View huff's profile
2828 posts in 3218 days
#4 posted 09-04-2013 01:35 AM
I think Mark pretty well covered it for you; if you’re in the market to buy a compressor and gun strictly for finishing, then I would also suggest you try an HVLP unit.
In my business I sprayed pre-catalyzed lacquers and used a large commercial compressor and a Devilibess spray gun, but at my home shop I use the Earlex 5500 HVLP, spraying the same finishes and get great results.
I like the protability of the HVLP plus not having to worry with regulators, seperators and making sure no water is in the lines.
-- John @
Shawn Masterson
1324 posts in 1882 days
#5 posted 09-04-2013 04:07 PM
While I agree somewhat with mark, but I feel that is a lot of cash for a machine that does 1 thing. For the non commercial app I would go for a 60 gallon compressor and a HF gun. the reason is when you are done then you can still use the compressor for whatever you need. also if the gun gets messed up(dropped or not cleaned properly) then you pitch it and get another one, they are only 10-20 bucks. Thats how I roll
View NiteWalker's profile
2736 posts in 2510 days
#6 posted 09-04-2013 10:18 PM
I faced this dilemma a while back and decided on a turbine unit.
For what I would have spent on a new, bigger compressor and a full size gun, I would have spent the same as I did on my turbine (fuji minimite 4). I’m much happier with the turbine system.
