Splayed Miters?
Forum topic by lumberjoe posted 09-03-2013 06:38 PM 4025 views 0 times favorited 5 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2899 posts in 2486 days
09-03-2013 06:38 PM
I want to make another serving tray, but I want to use splayed miters. I can’t for the life of me figure out the math of how to get a proper splayed miter (rectangle) with a flat bottom. Any tips or places to look?
5 replies so far
View Jim Finn's profile
Jim Finn
2688 posts in 3159 days
#1 posted 09-03-2013 08:20 PM
I have a chart for just that but I never splay anything out past five degrees and I have found that a simple 45 degree cut at this five degree angle works just fine. Five degrees will work well with a serving tray, in my opinion. Over five degrees it starts to become an issue. Experiment with five degrees and see what you like.
-- No PHD just a DD214 Website> craftingcouple.com
View Handtooler's profile
Handtooler
1628 posts in 2369 days
#2 posted 09-03-2013 08:40 PM
There’s a great chart, instrustions and pictures on BING “splayed miters”. Also Shop Smith gave instructions for this as far back as 19787 when I got my machine. Just go internet shopping. Good luck!
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View DrDirt's profile
DrDirt
4526 posts in 3979 days
#3 posted 09-03-2013 08:53 PM
http://woodgears.ca/miter/splayed_miters.pdf
Above is the chart Handtooler mentioned
You just decide how many sides, and what angle you want to lay out at and it will give you the settings for the compound cut.
lumberjoe
#4 posted 09-04-2013 02:08 PM
Thanks. The 45 and 5 works for me. Since I want the tray to sit flat, Should I assume I need to cut a 5 degree bevel on the bottom edge first?
Jim Finn
#5 posted 09-05-2013 02:44 AM
Yes, 5 Degrees on the bottom edge should to the trick.
