Mobile Base for Ridgid R4511
Forum topic by ChipByrd posted 09-03-2013 05:29 PM 3197 views 2 times favorited 8 replies Add to Favorites Watch
View ChipByrd's profile
ChipByrd
146 posts in 1925 days
09-03-2013 05:29 PM
I have this saw, and the mobile lift isn’t working. I also have a set of these casters from Woodcraft: http://www.woodcraft.com/Product/2021166/25291/WoodRiver-Machine-Leveling-Caster-Plate-Mounted-4-Pack.aspx
I was thinking about laminating two 3/4” pieces of plywood and attaching these casters right under where the legs are. And then setting the saw on the plywood and connecting the saw feet to the plywood with lag bolts.
Would this work?
The main reason I am going this route is that I have the plywood and casters.
Thanks,
Chip
8 replies so far
View crank49's profile
crank49
4030 posts in 2969 days
#1 posted 09-03-2013 06:50 PM
I think it would work as long as you don’t need to move the saw very often.
That would be a lot of hassle to have to get under the saw to screw the pads up and down on all four corners every time you want move the saw.
On second thought, that would not work for me at all. I could design a leaver operated caster system that would be no more trouble to build and install and would be a great deal more useful. In fact, there is a design in the last issue of Shop Notes magazine.
View distrbd's profile
distrbd
2252 posts in 2445 days
#2 posted 09-03-2013 08:05 PM
There’s a mobile base specifically made for older 3650 Ridgid that is very simple and easy to build ,2 castors in the back and one with a lift in the front:
http://www.youtube.com/watch?v=PHnv15TOWX8
-- Ken from Ontario, Canada
ChipByrd
#3 posted 09-03-2013 08:20 PM
I rarely, if ever move the saw. Just want them for that rare occasion. One of the reasons I was thinking of going this route is that I already have all I need :).
crank49
#4 posted 09-04-2013 12:09 AM
”for that rare occasion”
Well, for that they would work.
View toolie's profile
toolie
2122 posts in 2627 days
#5 posted 09-05-2013 09:19 PM
i’d find out what the problem is. i have both of my TSs on herc-u-lifts and find them to be exemplary full mobility bases.
View gtbuzz's profile
gtbuzz
427 posts in 2440 days
#6 posted 09-05-2013 09:32 PM
I have very similar casters that I purchased from McMaster Carr and love them. I attached them to the stand for my Delta 46-460 lathe. When the feet are extended (ie casters “retracted”), it’s very stable. I don’t see any issue with stability. It’s not all that much of a pain to move either, so especially if its an occasional move, I wouldn’t worry about it.
The one thing you’ll want to be careful about is that you’re increasing the height of the table about 3-4” with this method. For my lathe, I was able to lower the height of the stand a little, so it turned out to mostly be a wash once I lost the height of the existing feet as well. I’m only 5’7” so something like this matters a little more to me than with other people.
View cutworm's profile
cutworm
1075 posts in 2792 days
#7 posted 09-06-2013 12:03 AM
Probably assembled wrong. The directions aren’t great. I suggested to Ridgid that they put labels on the pieces – A, B, C, etc. On the instructions I have they all look the same on the drawing. As I recall I found a parts list that helped.
-- Steve - "Never Give Up"
View dogmir's profile
dogmir
25 posts in 1971 days
#8 posted 09-06-2013 01:02 AM
I have an identical saw sold under another brand. Made by Orion/Steel City. Mine is blue with a cast iron top. I put these on and love them.
Contractor saw casters
