Glue to use for sanding discs
Forum topic by derrickparks57 posted 09-03-2013 02:12 PM 14183 views 0 times favorited 19 replies Add to Favorites Watch
View derrickparks57's profile
derrickparks57
129 posts in 1990 days
09-03-2013 02:12 PM
I cut out some 9” sanding discs for my disc sander last night and coated the back real good with spray adhesive. Slapped it on the faceplate and held it with some pressure for about ten minutes, and it held on pretty good. This morning I stroll out to the shop and it had fallen off.
I’m using heavy duty sandpaper and the faceplate is metal, if that makes a difference.
So my question is…What glue do you guys use?
-- Derrick, Florida, DP Woodwerks
19 replies so far
View crank49's profile
crank49
4032 posts in 3090 days
#1 posted 09-03-2013 02:24 PM
I don’t know what kind of glue is in your spray adhesive, but mine is contact cement.
Contact cement must be applied to both surfaces and allowed to dry before you bring the surfaces together.
My biggest problem with this stuff is that removal is very difficult. They make kits to convert these sanders to “hook & loop” type attachment. My disk sander is 12” and I plan to convert it once I fix all the rest of the world’s problems.
derrickparks57
#2 posted 09-03-2013 02:31 PM
I’ll have to look at it this evening after work to see what the glue type is. I’ll have to try applying it to both surfaces, I only put it on the sandpaper last night.
View Bogeyguy's profile
Bogeyguy
548 posts in 2187 days
#3 posted 09-03-2013 02:48 PM
There used to be a product available that came in a cardboard tube, about 1 1/2” diam. about 12” long and it was a thick paste type product that you opened the end and turned on the sander and held it against the steel plate and dressed the plate all way across. Placed the disc on the plate and lightly run a board across the entire sanding disc ti smooth out. This was a loooong time ago, so not sure if it’s still around. Removal of the disc was simple and easy. Then apply another light coat of the adhesive and repeat.
-- Art, Pittsburgh.
Bogeyguy
#4 posted 09-03-2013 02:48 PM
Derick, don’t use contact cement. You’ll be sorry.
-- Art, Pittsburgh.
View REO's profile
REO
929 posts in 2193 days
#5 posted 09-03-2013 02:57 PM
The spray adhesive works but both pieces should be sprayed, allowed to dry about 5-10 minutes and then joined.
automotive trim adhesive works but it is a pain to clean off.
acetone will take most adhesives in a hurry, WD40 works as an adhesive remover as well but that in turn has to be cleaned off prior to mounting a new disc.
Bogeyguy
#6 posted 09-03-2013 03:01 PM
Did a google for the “stuff” I used years ago as an apprentice in a cabinet shop. No luck. It was a great product.
-- Art, Pittsburgh.
View shipwright's profile
shipwright
8068 posts in 2917 days
#7 posted 09-03-2013 03:26 PM
Before adhesive backed discs took over all the sanding discs I used were attached to the pads with this stuff from 3M. It sticks well and is removable, although you may have to heat it a little. Still available mostly at automotive supply stores.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2882 days
#8 posted 09-03-2013 03:38 PM
crank49: The H&L conversion is a blessing in disguise.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View DrDirt's profile
DrDirt
4451 posts in 3861 days
#9 posted 09-03-2013 05:11 PM
http://www.freemansupply.com/LatexDiscCement.htm
I have not used this – it seems to be a contact cement – but perhaps with a different chemistry that makes it less challenging to remove than the contact cement from Lowes for Formica.
I just have PSA discs
Also there is “feathering disc adhesive” that you can get at the auto parts store for gluing discs to rubber backers.
I have used it for disc sanding auto body – but there I am only expecting the glue to hold for 20 minutes use or so before changing discs.
derrickparks57
#10 posted 09-03-2013 10:31 PM
Thanks for all the input. I’ll try using the spray adhesive on both surfaces if that doesn’t work I’ll pick up some of the 3M stuff.
117203 posts in 3696 days
#11 posted 09-04-2013 01:43 AM
I agree with using feathering disc adhesive just use a small amount spread around on each side. I works fine.
View MrRon's profile
MrRon
4991 posts in 3362 days
#12 posted 09-04-2013 09:18 PM
Try rubber cement.
View cj08758's profile
cj08758
1 post in 203 days
#13 posted 03-04-2018 03:05 AM
I always used Titebond’s Franklin Sanding Disc Cement which worked very well and lasted quite long. it was made by Franklin International product code 0-37083-05043-1 but I can’t seem to find it anywhere. Their website is http://www.franklininternational.com/home.aspx – hanen’t contacted anyone there yet as I still have most of an 8 oz bottle left. hope this helps.
View jbay's profile
jbay
2593 posts in 1018 days
#14 posted 03-04-2018 03:20 AM
Thanks for all the input. I ll try using the spray adhesive on both surfaces if that doesn t work I ll pick up some of the 3M stuff.
- derrickparks57
Any solvent based contact cement, or 3m spray 90, or even 3m spray 77
It peels right of with lacquer thinner.
Whenever I miss stick a piece of laminate, I use lacquer thinner to peel it off. Works easily.
View Woodknack's profile
Woodknack
12336 posts in 2499 days
#15 posted 03-04-2018 03:56 AM
Hopefully Derrick has figured it out by now
