Two-way drawers
Forum topic by gepatino posted 09-03-2013 02:03 PM 1376 views 0 times favorited 7 replies Add to Favorites Watch
View gepatino's profile
gepatino
217 posts in 2094 days
09-03-2013 02:03 PM
Topic tags/keywords: question
I’m was thinking in making some 2-way drawers for a bar that divides a kitchen and the living, so you could open these drawers from both sides.
The easiest way would be to make a simple drawer and let it slide from one side to the other. I was trying to figure out how to make it lock in the closed position so you don’t end with half opened drawers.
I’ve found some sliders online, but I’m not sure I can find them here (Argentina).
My first idea war to put some blocks under the drawer near the front and end, and make them stop at the inner side of the frame. To open the drawer you sould lift your side, then pull.
The stop blocks could have a slope in the inner side, so when you push the drawer in it lifts until the block falls into the stop position.
The thins I don’t like about this is that the front of the drawers has to be a bit shorter in height than the slot were ir runs (to allow you to lift the drawer before pulling).
Any ideas? How are 2-way drawers make without special hardware?
Thanks a lot
(sorry about the writting, english is not my mother tongue and being a super rookie in woodworking it’s hard to find the right words)
-- http://about.me/gepatino
7 replies so far
View GrandpaLen's profile
GrandpaLen
1650 posts in 2242 days
#1 posted 09-03-2013 03:57 PM
gepatino,
I believe a Bullet catch or Ball catch would serve the purpose of a push/pull latch to keep your drawers in the closed position.
Here are 3 sources for these catches.
- http://woodworker.com/14-solid-brass-cylindrical-ball-catch-mssu-163-688.asp
- http://www.amazon.com/Brusso-Solid-Brass-Bullet-BC-265/dp/B000BSI9S6/ref=sr_1_2/180-1131084-4608215?ie=UTF8&qid=1378223065&sr=8-2&keywords=bullet+latch
- http://www.rockler.com/product.cfm?page=145
You may be able to find these locally at a Hardware or Home Center.
Hope this helps your search.
Best Regards. – Grandpa Len.
Work Safely and have Fun.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View Marpintero's profile
Marpintero
211 posts in 3257 days
#2 posted 09-03-2013 06:13 PM
Hola Gepatino. En general, los cajones de doble vía no tiene topes en la posición de cerrado, pero sí en los extremos para que no se salgan al abrirlos totalmente. ¿Cómo se logra que queden cerrados en la posición correcta?: sencillamente a ojo o apoyando la mano o un dedo en el frente que estamos cerrando hasta que haga tope con el mueble.
Sólo le molesta a personas perfeccionistas que los cajones no queden exactamente cerrados (a mi me molestaría, jajaja), así que te voy a dar dos soluciones que se me ocurren:
1º) Correderas telescópicas. Como vos decís, existen correderas telescópicas de doble vía, pero no creo que se consigan en Argentina. De todas maneras podés averiguar con la gente de Hafele, que son lo mejor que se consigue en el país, o con la gente de Ducasse, que también tiene buenos productos.
Si no llegan a tener un corredera de doble vía, podés intentar fabricarla con dos juegos de correderas simples:
- el primer juego va entre el cajón y un soporte (lateral o inferior, depende que correderas quieras usar)
- el segundo juego va entre el soporte y el mueble (en la dirección contraria).
Lo bueno de este sistema es que se puede abrir completamente el cajón por ambos lados. Igual yo haria unas pruebas para ver que funcione, ya que por la fricción que tienen este tipo de correderas, podría llegar a abrirse la que esta cerrada mientras cerras la que esta abierta (¿se entiende?). En todo caso te recomiendo las que vienen con sistema cierra suave automático, que tal vez mitiguen un poco esta situación (y además son re faroleras, el cajón se cierra solo!).
2º) Inspirado un poco en la respuesta de GrandpaLen, se me ocurre una solución un poco más casera y barata:
- realizá un canaleta semicircular en los laterales del cajón (con una fresa tipo cove bit), que no llegue hasta los frentes del cajón (stop groove). El largo de la canaleta te lo define cuánto querés que salga el cajón hacia afuera).
- realizá la misma canaleta en el mueble.
- en el centro de la longitud de las canaletas, profundizá unos 2mm para generar un diente (lo que va a detener el cajón en la posición de cerrado). Esto se logra presionando el router (plouge router) en el lugar, mejor si lo fijás así no se corre.
- colocá una bolita de vidrio o de metal en las correderas.
El sistema debería quedar apretadito, para que la bolita sea obligada a girar. No lubriques las canaletas ni la bolita, esta tiene que girar, no deslizar. De este modo, al cerrar el cajón la bolita viaja hasta el centro de las canaletas y se traba ligeramente en el diente. Y cuando abrís el cajón, la bolita viaja hasta el extremo de las canaletas y hace de tope para que el cajón no se salga.
Suponiendo que este sistema pueda funcionar, el problema principal reside en cómo meter la bolita en las canaletas y en la posición correcta… Yo propongo que hagas una caja exterior que contenga el cajón (y donde hacés la canaleta del mueble), y que coloques la bolita mientras armás el cajón (con tornillos para poder desarmarlo si algo se rompe). Luego colocás la caja (con el cajón ya funcionando) dentro del mueble.
Si no se entiende alguna de las propuestas avisame que intento hacer un dibujo.
Un abrazo.
Martín
-- Our lives are marked and bound together by concentric rings. Martín - Argentina
View Kaleb the Swede's profile
Kaleb the Swede
1827 posts in 1939 days
#3 posted 09-03-2013 06:36 PM
How about a magnet in the middle of the drawer runner that catches the bottom of the drawer. I saw that in a tauntaun book.
-- Just trying to build something beautiful
View rejo55's profile
rejo55
190 posts in 2212 days
#4 posted 09-03-2013 06:38 PM
Pienso que la solucion de Marpintero es un buen idea.
Tenga un buen dia
Joe
-- rejo55, East Texas
gepatino
#5 posted 09-03-2013 06:44 PM
Gracias Marpintero, voy a tener en cuenta lo de la bolita, suena interesante.
Kaleb, I really like the idea of magnets. I only have to find some that are strong enough.
View AlaskaGuy's profile
AlaskaGuy
4053 posts in 2279 days
#6 posted 09-03-2013 07:40 PM
This is what I’d be using. They have an Internal Detent Secures In Center/closed Position.
http://www.drawerslides.com/accuride-2002-two-way-travel-drawer-slide?gclid=COPYlZ79r7kCFfF34god2D8Aiw
Marpintero
#7 posted 09-03-2013 08:53 PM
La idea de Kaleb es una idea muy buena y simple, pero creo que su utilidad puede depender del peso del cajón (y lo que vaya a contener). A entender, cuanto más liviano, mejor funcionará.
Otra solución que se me ocurre es colocar una rueda de este tipo en el mueble, sobre la cual deslizará el cajón, y hacer en la corredera del mismo un rebaje para que calce cuando esta en la posición cerrado. En este caso se puede obviar el efecto de tope para que no se salga el cajón, pero de última, no es el principal problema.
