Blade thickness for fret saw for dovetail waste
« back to Hand Tools forum
Forum topic by siavosh posted 09-03-2013 05:31 AM 1559 views 0 times favorited 3 replies Add to Favorites Watch
View siavosh's profile
siavosh
674 posts in 2105 days
09-03-2013 05:31 AM
Topic tags/keywords: fret saw blade
Hi folks, I’m researching fret saws for cutting out dovetail waste and had a question: my dovetail saw leaves a very fine kerf, 0.010”. What thickness blade for a fret saw blade would you recommend? Or is that kerf too thin to get a good blade through the cut to reach the baseline without damaging the blade too easily?
Thanks.
-- http://woodspotting.com/ -- Discover the most interesting woodworking blogs from around the world
3 replies so far
View Loren's profile
10477 posts in 3882 days
#1 posted 09-03-2013 06:04 AM
It doesn’t matter a lot. You may scratch the kerfs getting
the fret saw in there, but it won’t be enough to mess
up the fit. Thin blades, front to back, break easier. At
some point you have to go pinless and use a jeweler’s
saw but then there are a lot of teeth and the process
gets slowed down.
View LRR's profile
LRR
25 posts in 2057 days
#2 posted 09-03-2013 12:33 PM
You may want to email or call a vendor like craftsmanstudio.com. I have the LN thin kerf dovetail, and they let me know if the blade in question would work. Or you could check with someone like bensscrollsaw.com. They might be able to help. I know that Ben’s sells a Pégas ultra thin blade 0.0076 thickness which might work. (no affiliation to either location). Pégas is often recommend for use with the Knew Concepts saw. Is your saw a Japanese saw?
siavosh
#3 posted 09-03-2013 06:50 PM
Thanks folks. LRR – yeah, it’s the new Lee Valley super fine dozuki. I’ll send those vendors an email to see what they recommend, thanks again.
