Cracked and split barnwood
Forum topic by MT_Stringer posted 09-02-2013 12:53 AM 2103 views 0 times favorited 9 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3153 posts in 3134 days
09-02-2013 12:53 AM
Topic tags/keywords: question pine clamp
Just a quick question. I have a piece of 1×12 55 inches long that I plan to use make a picture frame. It is reclaimed barn wood and very weathered – cracks and a few splits.
My plan is to rip it and miter the joints so no fresh cuts are showing. It will not be stained or finished, just left natural.
What would you suggest I use to stabilize the cracks?
Glue – what kind?
I have some Gorilla glue (the kind that swells when it cures)
Titebond Original and III
Superglue
I am afraid when I rip it it will come apart so I am trying to stop the cracks before I start. I figured I would glue and clamp and let it sit overnight.
Note: This frame will be for our first great grandchild. He is going to be a cowboy, just doesn’t know it yet (due mid November). Weathered barn wood with barbed wire attached.
Here is a pic of the wood.
9 replies so far
View Handtooler's profile
Handtooler
1497 posts in 2035 days
#1 posted 09-02-2013 01:29 AM
In the USAF for aircraft metal cracks they “Stop Drill” a hohe just slightly larger than the end of the crack at either/both ends. I’ve never heard of it in woodworking, but since the wood will maintain its weathered look I’ll bet it would aid in preventing the cracks from continuing, addition to an adheasive of your choice??
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Dallas's profile
Dallas
3599 posts in 2390 days
#2 posted 09-02-2013 01:49 AM
White glue… clamp. Let dry, do what you need to.
Stop hole like with metal don’t work to well…... because the grain of the wood continues past whatever break there is.
MT_Stringer
#3 posted 09-02-2013 02:15 AM
Thanks for the replies.
The wood appears to be gray with some red and brown colors. The TBIII is the closest I have. So I am fixin’ to add a little to the large cracks, clamp and wipe. May have to do it a couple of times.
MT_Stringer
#4 posted 09-02-2013 02:40 AM
OKay…Drizzled some glue in the big cracks and splits (from the back side) and clamped them enough to close up the cracks. Gave it a good wipe down. I think any help will be a big help when it comes time to fire up the table saw.
Backside
Front
Handtooler
#5 posted 09-02-2013 09:57 AM
Thanks Dallas!
Dallas
#6 posted 09-02-2013 10:22 AM
To draw the glue into the crack you can always hold a vacuum cleaner hose on one side of the crack and dribble glue into the crack on the other side, the vacuum will draw the glue in.
View rrww's profile
rrww
263 posts in 2016 days
#7 posted 09-02-2013 11:54 AM
If you have any glue that squeezes out the front you can hit it right away with a wire brush (by hand).
View Roger's profile
Roger
20904 posts in 2707 days
#8 posted 09-02-2013 12:15 PM
Sounds like a nice project. Will be interesting
MT_Stringer
#9 posted 09-02-2013 06:32 PM
Good idea Dallas. I need to remember that.
Well, it looks like I may have been successful. I must have done a good job of wiping down after the glue up because there is only a small amount that I can see and that may not even get used once the board is cut up.
Thanks for the advice. I will post pics when the frame is finished.
Mike
