4" Dust Collector to Bosch 4100 2.5"
Forum topic by Sunstealer73 posted 09-01-2013 07:34 PM 3410 views 1 time favorited 7 replies Add to Favorites Watch
View Sunstealer73's profile
Sunstealer73
183 posts in 2334 days
09-01-2013 07:34 PM
I finally bought a dust collector after using a shop vac for a while. The last straw was a recent project with lots of melamine that made a huge mess in my shop. I went with the Harbor Freight model for $150 with 25% coupon. My shop is multi-purpose car/wood, so I can’t really install permanent lines for now. My planer and joiner both hook up easy with the 4” flex hose. I am running into a problem with the Bosch 4100 table saw though. The built-in dust port is 2.5”, but the adapters I bought are too bulky to fit correctly. They hit the plastic around the port. I modded a shop vac hose that is small enough to fit inside the port, but the suction drop is terrible with that setup.
What type of adapter do I need to go from the saw’s 2.5” port to my 4” hose that is small enough to not hit on the plastic around the dust collection port?
7 replies so far
Shawn Masterson
1325 posts in 2190 days
#1 posted 09-02-2013 01:36 AM
go to the plumbing section at the local BORG. you will find fernco's They are really great for bastard conections
View josephf's profile
josephf
213 posts in 2338 days
#2 posted 09-08-2013 04:29 PM
cut a bigger hole and add a 4” port .
View Splinter12's profile
Splinter12
55 posts in 2357 days
#3 posted 09-08-2013 05:33 PM
I liked that saw but hated the dust collection, good luck.
View fuigb's profile
fuigb
542 posts in 3199 days
#4 posted 09-08-2013 06:15 PM
Sun, you might be out of luck. I’m in a similar place, starting with the 4100 Bosch and down to the lack of a dedicated shop. The connection problem can be overcome with one of the universal adapters made of rubber (ten bucks at Menards or Sears) or the Fernco. However the real problem, I’ve found, is that the 4100 is a bugger to close off and thereby get sufficient suction to grab the dust and chips. I run a 1 3/4 horse Powermatic collector that is awesome but cannot gets it’s arms around the 4100’s dust. Best I’ve been able to do is to plug as many of the holes as is possible with rags and pipe insulation, and then I’ve adapted a piece of cardboard to fit across the bottom of the saw. Thus I’ve gone from capturing maybe ten percent of the dust up to 30 or 40’percent. Next gauntlet that I’ll drop is a hose hooked to a hood, but really the best option is to just roll the damn thing out to driveway and then clean up with a broom.
-- - Crud. Go tell your mother that I need a Band-aid.
View Grandpa's profile
Grandpa
3261 posts in 2917 days
#5 posted 09-23-2013 03:38 PM
Are you sure the problem is a leak or is the vacuum “cavitating”? That is what it is called when a centrifugal pump can’t get enough liquid to pump. When the vac can’t get enough air to move it moves nothing. Try opening more blast gates or allow more air to get into the system.
View jshroyer's profile
jshroyer
80 posts in 1900 days
#6 posted 11-10-2013 02:32 PM
I have added cardboard to the bottom with a small opening at the back. Also for the dust collector i dont have a large shopvac (1 gal, 1hp, fills up in around 15sec) and am waiting on getting one so i have added some super cheap blue HVAC filters to the back of my table saw. It makes the shavings hit it and drop to the ground into two buckets i have sitting there. not very fancy or efficient but works for now. Just really bad when i cut a lot of stuff.
-- http://semiww.org/
View b2rtch's profile
b2rtch
4868 posts in 3290 days
#7 posted 11-10-2013 03:22 PM
Cut a bigger hole in the table saw( 4”).
Restricting the air flow to much will just cause the DC to cavitate and to not work at all.
I had the experience going from 6” to 3” with my Clear View, with a 3” restriction it just quite sucking all together.
-- Bert
