SealCoat streaks
Forum topic by Matt Przybylski posted 09-01-2013 02:06 PM 1284 views 0 times favorited 7 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
546 posts in 2378 days
09-01-2013 02:06 PM
Topic tags/keywords: stain marks streaks sealcoat
So I was sealing in some gel stain yesterday on red oak and I brushed on Zinsser SealCoat. The stuff dries extremely fast and as I was brushing it, it would dry in one spot before I could blend it. Today I see there is some overlap marks that stick up in some spots. What’s the best course of action now to even this out? I want to get the overlap marks out before I spray on enduro var by GF. Should I lightly sand with something like 320? I want to make sure I don’t lift up the color. After sanding should I wipe the dust off with mineral spirits or something else?
Appreciate any help offered.
-- Matt, Arizona, http://www.reintroducing.com
7 replies so far
View JollyGreen67's profile
JollyGreen67
1669 posts in 2763 days
#1 posted 09-01-2013 04:03 PM
I have the same problem with turnings, trying to keep a wet edge is not happening. I even tried rubbing out with lots of DNA – didn’t work. I don’t use it anymore, only Deft Sealant, which does not streak.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View NiteWalker's profile
NiteWalker
2737 posts in 2577 days
#2 posted 09-01-2013 04:45 PM
I usually lightly sand with 320.
It works fine.
Matt Przybylski
#3 posted 09-01-2013 09:04 PM
I sanded lightly with 320 on a test piece I had and I basically went right through the shellac and even took down some color. I was sanding REALLY lightly too, so that scared me off and I’ve decided not to sand and hope that the enduro var evens everything out when I spray it on :/
View JAAune's profile
JAAune
1799 posts in 2317 days
#4 posted 09-01-2013 09:56 PM
SealCoat comes in either a 2lb or 3lb cut. I don’t remember which. Regardless, it’s a lot easier to brush on if it’s thinned with about 50% denatured alcohol first. I prefer a synthetic brush with fine, flagged bristles and a chiseled tip.
Since it’s too late now for you to use proper technique for applying the shellac I recommend moving onto the topcoat as you said you planned to do. After a coat or two of Enduro you can scuff sand everything to level out minor defects prior to applying the final coat.
As a side note, is that Enduro the water-based product? If not, I’m not sure why you are spraying the varnish but didn’t use your spray gun to apply the shellac. It’s generally best to spray the sealer over the stain whenever possible to minimize the chance of the stain getting moved around by the brush-strokes.
View Finisherman's profile
Finisherman
227 posts in 1850 days
#5 posted 09-01-2013 10:42 PM
I strongly recommend that you don’t try to spray another coat of finish over the shellac in hopes that it will even everything out. It rarely works that way. Rather, the defect will usually telegraph through your topcoat. Instead, use a single edged razor blade like a cabinet scraper to carefully level the ridges. Next, try thinning your shellac with anhydrous isopropyl alcohol, if you can find it. Try to apply your shellac in the cool of the evening or the early morning. Finally, as a last resort, you can try adding some lacquer retarder to your shellac to give you more open time. JAAune is right. Spraying your shellac is the best way to ensure an even coat.
View Clint Searl's profile
Clint Searl
1533 posts in 2362 days
#6 posted 09-01-2013 11:57 PM
That’s what you get when you use a superfluous product, which shellac is.
Matt Przybylski
#7 posted 09-01-2013 11:57 PM
JAAune, I didn’t spray the shellac out of pure laziness. You see, it was just four panels and I figured I’d just brush it on quickly and then when I’m ready to apply shellac to all other parts I’d spray the rest, many more parts than just the door panels, so I could clean the gun then. However, as usual, when you try to take shortcuts you get burned and I did. Lesson learned :/
