Screws ALWAYS needed?
Forum topic by pashley posted 376 days ago 208 views 0 times favorited 10 replies Add to Favorites Watch
View pashley's profile
pashley
529 posts in 613 days
376 days ago
Topic tags/keywords: glue
So I’m working on this little clock from a plan in a magazine.
It has a 1/2” sub-base and sub-top which would attach the bottom and top.
In the plan, it calls for for countersunk holes to do the attaching.
So, I did that, and drove the screws. Right through the top. Nice.
So then I’m thinking, “Were screws really needed here? Wouldn’t glue be plenty? I’m looking at about 15 square inches of glue area! Why bother with setting up the holes, countersinking them, pilot-holing the attaching piece and then turning screws in a difficult spot?”
Jeez, couldn’t I just have glued the darn thing, and saved A LOT of time?!
What do you guys think?!
-- http://newmissionworkshop.com
View Garyb6's profile
Garyb6
262 posts in 526 days
376 days ago
If you can keep the pieces from sliding out of position during glue up I would think glue alone would suffice.
-- Garyb6, “Make everything as simple as possible, but not simpler” - Albert Einstein
View bbqking's profile
bbqking
332 posts in 619 days
376 days ago
Cut “keeper blocks” from scrap, clamp them to keep everything where you want it, and use glue only. I make lots of clocks and this is the way to go if it works for your design. Many times magazines will suggest these types of connections to ensure a successful completion and no complaints.
-- bbqKing, Lawrenceville
View JWTIII's profile
JWTIII
13 posts in 380 days
373 days ago
I am in agreement with the glue-only approach. The only thing to watch out for is cross-grain glueing, but for smaller projects that should ne minimal.
John
View Don Newton's profile
Don Newton
532 posts in 514 days
373 days ago
A lot of times I will glue a piece and then use a couple of screws for clamping. But then again my old Scottish Grandfather used to wear suspenders AND a belt.
-- Don, Pittsburgh
View DaveR's profile
DaveR
1527 posts in 616 days
373 days ago
I think you should have added a couple of ring shank nails. too. ;)
Glue alone is good. if you need something just for alignment, a couple of tiny brads could be driven into the “bottom” piece and clipped off just proud. Then the other piece won’t side around once it is slick with glue.
-- Until you spread your wings, you'll have no idea how far you can walk.
View ghazard's profile
ghazard
145 posts in 405 days
373 days ago
DaveR…I was just visualizing what you are describing there…that is a great idea! You get the benefit of having small nails for alignment but nothing shows. I need to remember that one!
(Sorry, Pashley, I can’t be of assistance on the original question…no experience there.)
-- If, in your life, you attain the means to help; you incur the responsibility to act.
pashley
373 days ago
Ditto.
I’ve seen this little tool somewhere, for just this type of thing. It’s basically a very small V-shaped gouge. You gouge the piece of wood a little, lift up a “flap” of wood, drive your brad, nail, pin, etc, sink it, and then put that wood flap back down, with a drop of glue, and there you are!
14926 posts in 747 days
373 days ago
Depending on the glue, I think the glue will do.
DaveR
373 days ago
Patrick, my suggestion was to drive the brad only into the second piece. Then you cut it off so it sticks up an 1/8” or so. It is sort of like using dowels for registering the other piece but it it a lot quicker to do. If you use a side cutter, it leaves the cut end of the brad sharp enough that you can press the piece being glued into place and clamp it up.
That way there’s no need to pry up a sliver of wood or glue it back down. And unless the piece being glued down is veneer, you won’t sand into the brad when finishing up.
pashley
373 days ago
Ok, gotcha, yeah, that makes sense.
