Which is less likely to cup on a 9" deep shelf, SYP or poplar?
Forum topic by 404 - Not Found posted 08-30-2013 11:31 PM 1443 views 0 times favorited 11 replies Add to Favorites Watch
404 - Not Found
2544 posts in 2967 days
08-30-2013 11:31 PM
I have a customer who wants long shelves made, supported by wooden brackets that use diagonal braces. The shelves and brackets will be painted white.
They are going to hold books and one of them is also longer than 8’, so man made board is out of the question.
My timber supplier has nice 10” wide 4/4 planks of SYP at 16’ long or there’s a few wide poplar 4/4 planks, 16’ long in the bale. Both are kiln dried and show no sign of cupping even though both are tangentially sawn.
Normally I’d make a shelf this wide by ripping a plank in half and gluing it together heart side up/heart side down to eliminate cupping. I don’t think there’s going to be the money in this little job to do that. Is it sufficient to have the shelf heart side up – and attached to the brackets with a screw in the centre to keep the middle pulled down flat? Or do I need to get my biscuit jointer out?
Which would you use?
11 replies so far
View kdc68's profile
kdc68
2657 posts in 2275 days
#1 posted 08-31-2013 01:18 AM
Your statement says both the shelves and brackets will be painted white. IMO, poplar has the advantage over pine for painting. Pine will have knots and would be more work for you to prep them so they don’t show when the paint is applied. If you are buying pine that is as clear as poplar, you may be paying more for the pine
-- Measure "at least" twice and cut once
View Buckethead's profile
Buckethead
3194 posts in 1867 days
#2 posted 08-31-2013 01:45 AM
I’m thinking poplar is more stable than pine to begin with.
Poplar-2
Pine-0
Pine might be less expensive though
-- Support woodworking hand models. Buy me a sawstop.
View jap's profile
jap
1251 posts in 2052 days
#3 posted 08-31-2013 01:49 AM
poplar
-- Joel
View redSLED's profile
redSLED
790 posts in 1890 days
#4 posted 08-31-2013 01:51 AM
poplar
View BentheViking's profile
BentheViking
1782 posts in 2562 days
#5 posted 08-31-2013 02:01 AM
poplar seems like the popular choice here
-- It's made of wood. Real sturdy.--Chubbs Peterson
View DKV's profile
DKV
3940 posts in 2502 days
#6 posted 08-31-2013 02:04 AM
But, which is less likely to cup?
-- This is a Troll Free zone.
View cutmantom's profile
cutmantom
405 posts in 3033 days
#7 posted 08-31-2013 03:02 AM
It really depends on the direction of the growth rings ,plain sawn vs quartersawn,but for a painted project poplar will give the better result
View NiteWalker's profile
NiteWalker
2737 posts in 2575 days
#8 posted 08-31-2013 03:07 AM
I use a good amount of kd poplar and have had little to no cupping, even on 8” wide boards. So I’d go with poplar. I don’t work with a lot of pine though, but like I said, no issues with poplar for me.
View RussellAP's profile
RussellAP
3104 posts in 2284 days
#9 posted 08-31-2013 03:25 AM
If cupping is a concern, dado a small depression about 2” from either end of the shelf and screw in a flat metal bar. Keep it flush with the wood and you can paint right over it. Guarantee it wont cup in a bog.
404 - Not Found
#10 posted 08-31-2013 01:15 PM
Poplar it is then, it’s a few euro less than the pine as well. Thanks for the input.
View Don W's profile
Don W
18715 posts in 2565 days
#11 posted 08-31-2013 01:19 PM
I agree 100% with poplar being the better choice.
