Milling machine question
Forum topic by Don W posted 08-30-2013 12:10 PM 3953 views 0 times favorited 14 replies Add to Favorites Watch
View Don W's profile
Don W
18672 posts in 2503 days
08-30-2013 12:10 PM
I know there are some metal guys out there. I may have a chance on a used machine. Its an older version (2 hp) of this
Asking price is $850. Thoughts?
-- - Collecting is an investment in the past, and the future.
14 replies so far
View lwllms's profile
555 posts in 3217 days
#1 posted 08-30-2013 01:03 PM
It really depends on the condition of the machine and what accessories are included. At a minimum you’ll also need a good vise, collet set, and end mills. I’d suggest a power feed and mist coolant system as well.
Don W
#2 posted 08-30-2013 01:25 PM
Thanks. I was looking more for thoughts on the mill, not so much the price, although those opinion are appreciated as well. I’ve never used a milling machine and have heard the round column machines are not as good. I just don’t know what “not as good” means when building small projects like I expect to do.
View JustJoe's profile
1554 posts in 1974 days
#3 posted 08-30-2013 01:35 PM
It’s not a true mill, it’s a mill-drill. I had one before I found my knee-mill. 2hp is more than enough power but these things are not very sturdy and if you are new to metalworking like I am, then they can be frustrating because the wrong speed/feed just makes everything vibrate and the whole machine shakes and the cutting bit just slams around or pulls out. I suppose if you are very experienced and have the patience to take very light cuts then you can make it work for iron/steel but I couldn’t. If you’re only going to do brass or aluminum then the learning curve is not as steep but the tool still has its limitations.
The head sits on a round column and it locks in place with two large bolts but if you try to take too heavy a cut in a hard metal then the slamming/vibration pushes the head to the side out of alignment. But again, if you’ve got the patience to torque it to 2.31bajillion pounds per inch, they’ll hold.
On the plus side, some people have managed to CNC convert these mill-drills – they’re all based off the same Rong Fu designs, or if you buy a power-feed (enco for a couple hundred bucks) for the X-feed then you can easily dial in just the right speed that doesn’t make the mill-drill act like it’s having an epilectic fit.
You said you weren’t concerned about the price but 850 is high end unless it comes with the stand, a set of r8 collets and an r8 chuck and some end-mills.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
#4 posted 08-30-2013 01:45 PM
Round column mill/drills are belt driven and square column units have geared heads. It’s not the column that makes the difference, it’s the drive system. Geared heads are easier and faster to change speeds. Also, if you need power down-feed you need a geared head. For plane making, I don’t think power down-feed is all that necessary.
Make sure the ways of a used machine aren’t worn and have been kept lubricated in use.
Other accessories you’ll need are a parallel set and a dial indicator for tramming in the vise (setting the vise so the fixed jaw is exactly parallel to X axis table travel).
View Mainiac Matt 's profile
Mainiac Matt
7815 posts in 2264 days
#5 posted 08-30-2013 02:05 PM
On the round collumn mill/drills, once you lock and tram the head, all of your Z-axis motion comes from the quill.
Two drawbacks with this are…
1.) If the quill travel is not enough to make your cuts, you have to lower the head…. BUT… every time you lower the head, you have to re-tram the mill….. can you say “pain in the butt”
2.) Even if the full range of motion of the quill allows you to make your cuts without moving the head, you may find yourself cutting with the quill at near full extension. This decreases ridgidity and increases vibration.
If I didn’t have a lot of space, or had no way to get a knee mill into my basement, I’d go for a RF-45 class machine with a dovetailed collumn. The G0619 good example. With these mills, the head moves up and down on a pair of dovetail ways and stays aligned through it’s range of motion. So you keep the quill fully retracted and then raise and lower the head to make your cuts.
If I had the space, I’d go for a knee mill, where the head is stationary and the table is raised and lowered on dovetailed ways.
Second hand Bridgeport clones can often be found for ~$1-2K
-- Pine is fine, but Oak's no joke!
View badcrayon's profile
38 posts in 1756 days
#6 posted 08-30-2013 02:10 PM
The price is too high unless it comes with a lot of tooling. I have owned this mill before it was just OK I would jump on it at 500 but at 850 I would hold out for a different mill. I have seen used Bridgeports for 1100 and up that’s a better choice if you have the room.
-- Bad Crayon Studio
View REO's profile
928 posts in 2009 days
#7 posted 08-30-2013 03:02 PM
provided the machine itself is in good shape that is not a bad price for an entry level machine. Machine tools have gone up in price the last several years and will eventually go down again for sure usually just after you buy the one that is available today. A decent vertical mill at least in my area is in the 2500 dollar range. I have seen a couple BP’s go for just over 1000 but they were sorry excuses for a vertical mill and wouldnt hold the tolerance of your machine on a good day. The screws were so bad that with all the adjustmant taken out of the nuts there was still .100 lash in the middle and you could barely get it to the end of the travel on either end. Whether it has power feed or not doesn’t make a difference on how the machine cuts. There is no tramming the head on these machines the head is either square to the table or you need to get it there. once square the head whether moved up or down the column will stay square. If the head rotates on the column it will change the dimension in the xy axis but it wont change the perpendicularity of the z axis. It depends on what your planned use is. Occasional drilling , boring, milling where there is time to take a few cut instead of hogging it all off at once or production runs. It would be the same comparison of a light duty metal lathe such as an atlas to an industrial machine like a monarch. There are thousands of people that are satisfied with an atlas in the basement or garage, but not so if they have to use one regularly to make a living. It should come with a set of collets and I am sure the one selling it would throw in a couple end mills to get you started.
10113 posts in 3583 days
#8 posted 08-30-2013 03:08 PM
I have one of those type things. It is cool, but I would not
pay that kind of money for it.
The reason is the quill does not stay centered when you move
the head on the column.
View darthford's profile
532 posts in 1859 days
#9 posted 08-30-2013 03:33 PM
Do not waste your money on that thing, here’s what you want.
Don W
#10 posted 08-30-2013 09:29 PM
Thanks for the responses. I really appreciate the help. I will probably hold out for something a little more suited.
View 69BBNova's profile
341 posts in 2152 days
#11 posted 08-30-2013 10:14 PM
Hey Don,
For more info you can go this site “Practical Machinist”, it has massive amount of information…
Be aware if you were to post don’t mention machines of Asian nature for the most part, they will rip you a new one (not exactly, just dont), unfortunately I think you have to sign up to see the images (cant quite remember)...
I found it when my friend gave me most of a South Bend War Production (WW2) 9B Toolroom lathe.
I seem to remember a lot of people like the Clausing 8520(?) for home use.
View rhett's profile
742 posts in 3602 days
#12 posted 08-30-2013 10:56 PM
At this point, looking at what you have made without a mill, you owe it to yourself to buy a quality tool that you can grow INTO.
-- Doubt kills more dreams than failure.
Don W
#13 posted 08-30-2013 10:57 PM
thanks Rhett
View bluekingfisher's profile
1250 posts in 2915 days
#14 posted 09-02-2013 08:11 AM
It’s only a bargain if you actually NEED it, otherwise it will soon become a “why did I buy that” Could be useful for those hand made plane beds you make.
Good luck on the decision.
-- No one plans to fail, they just, just fail to plan
