First for sale are a few chisels described below:
Chisels:
1. Greenlee 3/4" chisel, back lapped to 220 grit, 30 degree hollow grind from a Tormek, handle cleaned and given a citrus oil/bees wax. The handle has an area with some green stains, I didn't remove the stains. The chisel itself has been fully de-rusted and will need minimal set up work.
8$ plus shipping.
2. Buck Bros 3/8" chisel back lapped to 220 grit, 30 degree hollow grind from a Tormek, handle cleaned and
given a citrus oil/bees wax. The chisel itself has been fully de-rusted and will need minimal set up work.
8$ plus shipping.
3. Miller Falls 3/8" No.30 steel capped permaloid chisel. The chisel has its back lapped to 220 grit and hollow ground on a tormek to 30 degrees.
9$ plus shipping.
Shelton No. 4 Smoothing Plane. This is a Shelton made metal smoothing plane equivalent to a Stanley/Bailey No. 4. The plane itself is solid, no structural damage, the knob and tote are sound, this plane definitely would make a great tune up project for those of you who have never tuned up a plane and are scared. In construction, it appears similar to a Sargent, nice thick casting and similar lateral adjustment lever. This plane definitely has the bones to become a solid user.
12$ plus shipping.
Shinwa Handy Inkline Pro Jr. with almost new Tsuboman ink and 2 bamboo sumisashi, 1 new. The Shinwa Handly inkline was used a handful of times and the ink reservoir was filled with the tsuboman ink included. I used a bambo sumisashi but left the other one untouched, Inklines lay a very fine inkline that works well when dimensioning stock or for large layout duties. You can use the sumisashi like a knife that leaves a very fine line ink line for fine layout duties.
18$ plus shipping.
Irwin Expandable Auger Bit ( 5/8" to 1 3/4") in good condition. The bit looks like it received relatively little use if any at all.
8$ plus shipping.
Chisels:
8$ plus shipping.
8$ plus shipping.
9$ plus shipping.
12$ plus shipping.
18$ plus shipping.
8$ plus shipping.
