Shop made horizontal mortiser, still cutting
Forum topic by steve posted 08-28-2013 01:45 AM 1921 views 0 times favorited 5 replies Add to Favorites Watch
View steve's profile
steve
363 posts in 1869 days
08-28-2013 01:45 AM
It’s been a year since I’ve introduced this shop made mortiser.
Wanted to tell you all that it is still working well…if anyone needs plans, I have none, ha, but could guide you through it.
-- steve/USA
5 replies so far
404 - Not Found
2544 posts in 2845 days
#1 posted 08-28-2013 07:38 PM
Looks good, what’s the max depth of mortise you can achieve on that?
View MAKZ06's profile
MAKZ06
69 posts in 1681 days
#2 posted 08-28-2013 09:00 PM
Great looking setup. What kind of a geared lifting mechanism did you use on that?
steve
#3 posted 08-28-2013 10:26 PM
Depth: would be determined by the length of bit. I use spiral bits, and have no problem getting 2 inches, but I generally go 1-1 1/2 inch.
The geared mech. that raises and lowers the router is from a old craftsman 1966 Table saw fence. Rack and pinion, I guess you’d call it (Z)
The long handle is to bring table & (part) into bit (X)...the small handle, lower front, is for side to side action, (Y) mortice
Not sure which is X,Y, or Z, ha.
I use a roller bearing stand to do a mortice on the ends of long boards.
-- steve/USA
404 - Not Found
#4 posted 08-28-2013 10:36 PM
What is your cutting technique? I made a simple version with hand feed operation, where the material is ‘walked’ into cutter. Do you start shallow/push along/repeat til desired depth or full plunge holes along and clean out a with a full depth pass along the length? I ask for the benefit of anyone considering making one of these and because a proper hm like this is on my to do list.
steve
#5 posted 08-28-2013 11:25 PM
I tend to step down in depth as I clean out from side to side as I proceed in apprx. 1/4” depth at a time, I find it is less stress on the cutter, and makes a cleaner slot.
It is very fast, and using it with the vac attached, going in increments, the dust and shavings are picked up better.
Once the piece is clamped to the table, I simply work the handles, one into the bit, and the other from side to side to make the slots. I have stops set to make everything pre-set, and efficient
-- steve/USA
