laminated and tapered Butcher plane blade
« back to Hand Tools forum
Forum topic by planeBill posted 08-28-2013 01:41 AM 1182 views 0 times favorited 3 replies Add to Favorites Watch
View planeBill's profile
planeBill
506 posts in 2318 days
08-28-2013 01:41 AM
I know someone else had to have seen these on ebay. I bought an old Butcher (yes the chisel maker) plane blade that is both tapered in thickness, thick at the front and tapering towards the rear of the blade, and laminated. I hope to use it in a plane of my own construction someday so I thought I would give it a sharpening, NOT!! It is as hard as $#@&!! I finally had to resort to a 140 grit diamond plate and all it did was scratch the surface like everything else I tried. It is laminated just like a Japanese chisel or plane blade. I GROUND ON IT FOR THREE HOURS AND IT STILL HAS THAT PERFECTLY LITTLE SQUARE EDGE WHERE THE 0 BEVEL IS SUPPOSED TO BE, THAT IT HAD WHEN I STARTED SHARPENING IT. Sorry about the caps.
WTH!!
-- I was born at a very young age, as I grew up, I got older.
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3622 days
#1 posted 08-29-2013 02:59 AM
That sounds very hard; is it brittle? Could that be an artifact of surface hardening from some unusual use? On an inconspicuous spot can you try scratching it with a tungsten carbide tooth?
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1239 posts in 1623 days
#2 posted 09-27-2013 06:58 PM
How old is it?
If it is made from ordinary tool steel, what you describe is way too hard and it will chip or crack as soon as you use it.
Is it possible that it has been re-hardened at some time?
Try tempering the blade for 1 hour in your ordinary oven at 200-205 degrees celcius. This should releave any stress in the blade and give you a good, hard edge that grinds slow but keeps an edge a long time
Hope this works!
-- "Do or Do not. There is no try." - Yoda
View SRRieman's profile
SRRieman
65 posts in 2095 days
#3 posted 09-29-2013 04:16 AM
Butcher was a fairly large steel producer. They manufactured many things…ranging from steel ice skates to cutlery knives. I’m sure that they would have produced all their blades knowing that they would need to be sharpened and that it would need to be done …how to say it, not using some extraordinary methods. Best advice I can think to give you is to use waterstones or I would even try sandpaper. Remember laminated irons are different, microbevels and the ruler trick are your best bet, personally I would avoid the diamond stones. They take too long and will wear fast when sharpening hard steel. The square edge is throwing me off though…shoot some pics, upclose will help.
-- Scott Rieman
