What router bit do I need to make these?
Forum topic by noone posted 08-27-2013 06:24 PM 1312 views 0 times favorited 11 replies Add to Favorites Watch
View noone's profile
noone
584 posts in 2507 days
08-27-2013 06:24 PM
I’m unable to buy these two profiles locally, so my choices are to have a custom run of each or buy some router bits and get it done myself.
I’m thinking the latter, since I only need about 100 LF of one and 200 LF of the other.
Thoughts? Suggestions?
11 replies so far
View Dutchy's profile
Dutchy
3193 posts in 2403 days
#1 posted 08-27-2013 06:45 PM
Hello noone,
I certainly have an idea, but first need the profil sizes.
-- https://dutchypatterns.com/
Shawn Masterson
1325 posts in 2183 days
#2 posted 08-27-2013 06:59 PM
probably a panel raiser bits depending on the size. If it were me I would look at premade moldings and see if you could make something work
noone
#3 posted 08-27-2013 07:04 PM
Here’s the catalog I have access to here in Jacksonville, FL.
http://www.mouldingandmillwork.com/wp-content/uploads/IND6808_Orlando_Profile_Guide.pdf
Shawn- Do you see anything in here I can use? The limit of my creativity says “no”.
Dutchy- I am looking up the profile sizes now.
noone
#4 posted 08-27-2013 07:16 PM
Here is exactly what I need, dimensions included.
View dahenley's profile
dahenley
136 posts in 2328 days
#5 posted 08-27-2013 07:20 PM
looks like a cove bit (without the bearing and running the board flat) in the middle. and a round over bit at the bottom (with the wood standing on end).
depending on the profile of each, you might can connect them, or you might have to run it over the table saw to connect them. (to remove the middle)
but im just a hobbiest haha i have never done it before (but from my chair, it looks like if you ran those two, it would match up.
-- David Henley
Shawn Masterson
#6 posted 08-27-2013 09:02 PM
noone
#7 posted 08-27-2013 10:36 PM
Thanks.
Any other options for the build-up on the top of the wainscotting? Anything from this catalog that I can put together?
View HorizontalMike's profile
HorizontalMike
7770 posts in 3149 days
#8 posted 08-27-2013 11:34 PM
The one you are looking for for the base looks like a French Provincial Bit to me.
I bought a “small” 7/8in French Provincial Bit for just $32.50 from Magnate off of Amazon. I used it for the sticking in a small door:
http://www.amazon.com/gp/product/B0002JYA82/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
A more traditional size for the molding you are wanting to do would be the 1 1/8in Whiteside 3280 French Provincial Molding Router Bit 1/4” BD 1-3/4” D X 1-1/8” CL X 3-1/8” OL for $94.99 from WoodCraft:
http://www.woodcraft.com/PRODUCT/2008107/6203/WHITESIDE-3280-FRENCH-PROVINCIAL-MOLDING-ROUTER-BIT-14-BD-134-D-X-118-CL-X-318-OL.ASPX?refcode=10INGOPB&gclid=CM3huMjjnrkCFYdxQgod6gUAYg
117416 posts in 3812 days
#9 posted 08-27-2013 11:41 PM
Many profiles can be made with one bit it you have a good side router router table and speed control.
Like these :
http://www.amazon.com/CMT-856-802-11-Multiprofile-16-Inch-Diameter/dp/B000P4O68I/ref=sr_1_1?s=hi&ie=UTF8&qid=1377646710&sr=1-1&keywords=multi+profile+router+bit
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2590 days
#10 posted 08-28-2013 04:25 AM
well the smaller one is just an ogee on edge, but for the other, I’m afraid you’ll most likely only find that one in a shaper cuter.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
Dutchy
#11 posted 08-30-2013 07:04 PM
Hello noone,
Sorry I could not respond earlier.
