Fixing a non flush bevel at 45 degrees (the picture explains it all)
Forum topic by Sirgreggins posted 08-27-2013 12:26 AM 1849 views 0 times favorited 16 replies Add to Favorites Watch
View Sirgreggins's profile
Sirgreggins
299 posts in 2229 days
08-27-2013 12:26 AM
I know this sounds strange but the picture below will illustrate what happened. I made a cherry picture frame this weekend but during the clamping one of the corners slid up so the top of the face isnt flush. The problem with cleaning this up is tricky to me because i have cut bevels in the face of the frame. For the flat reveal i can use my block plane, but how do i flush up the bevel? Thanks
16 replies so far
View REO's profile
REO
928 posts in 2068 days
#1 posted 08-27-2013 12:51 AM
carefully use a chisle and blend over a distance? how did you fasten the corner. can you carefully separate itby breaking the glue line on the end grain? if that is possible reglue properly.
Sirgreggins
#2 posted 08-27-2013 01:17 AM
any recommendations on how to pull that corner apart without stressing the others? I used a bessey band clamp.
18149 posts in 1850 days
#3 posted 08-27-2013 01:35 AM
My thoughts are to take apart that joint from the back use a coping saw to get part way through and then drive a chisel in to split it. My concern is that even if you get it apart how are you going to get glue back in there. My more radical suggestion is use the miter saw and cut through all four joints and start over. The ends will be clean of glue and you won’t lose much in size.
View TimberFramerBob's profile
TimberFramerBob
68 posts in 1917 days
#4 posted 08-27-2013 01:39 AM
Miter gauge it at 45 degrees on a band saw very carefully and re-glue? technically it’ll be out of square but for a picture frame i doubt anyone would pick it up
-- ..........a man who works with his hands, his brains, and his heart.....is an artist.
View gfadvm's profile
gfadvm
14940 posts in 2684 days
#5 posted 08-27-2013 02:05 AM
You should be able to “unglue” that with a heat gun and then reglue it.
View 69BBNova's profile
69BBNova
341 posts in 2210 days
#6 posted 08-27-2013 02:11 AM
I can barely remember, but I swear I read somewhere on LJs about mineral spirits helping soften up a glue joint enough to break it free.
View cutmantom's profile
cutmantom
405 posts in 3029 days
#7 posted 08-27-2013 02:23 AM
Lacquer thinner not mineral spirits
69BBNova
#8 posted 08-27-2013 02:53 AM
Thanks for the correction cutmantom…
I knew I read something…lol
View tomd's profile
tomd
2155 posts in 3764 days
#9 posted 08-27-2013 03:02 AM
I agree with gfadvm a heat gun or if not available a hair dryer will heat up the glue, it will become soft again and release if you used woodworking glue.
-- Tom D
gfadvm
#10 posted 08-27-2013 03:07 AM
Not sure a hair dryer will work but worth a try if no heat gun available. If it doesn’t work, I would get a heat gun before I gave up.
Sirgreggins
#11 posted 08-27-2013 12:41 PM
thanks everyone. I will try the heat gun first. If this doesn’t work for any reason i’ll use my coping saw. LJ’s comes through for me again
View waho6o9's profile
waho6o9
8187 posts in 2570 days
#12 posted 08-27-2013 12:44 PM
A real thin kerf like a coping saw is the route I’d take as well.
Easy peasy.
View cabmaker's profile
cabmaker
1730 posts in 2803 days
#13 posted 08-27-2013 05:14 PM
Block plane would fix it. another way I have rectified similar problems is to bandsaw the bad joint and the adjacent , clean em up and re-glue .
View Moron's profile
Moron
5032 posts in 3887 days
#14 posted 08-27-2013 05:19 PM
without breaking the joint, the odds of making the error disappear are slim leaving it as unnoticeable as a missing front tooth.
If the miter joint is just butted (no spline/biscuit/tenon) then you should be able to use a hammer to break it, remembering to use a small scrap of wood as not to dent the frame
Good luck
Sirgreggins
#15 posted 08-27-2013 05:54 PM
i will take it apart and re glue. Once i have the joint the way i want and it’s dry, then i’ll put it splines
