TS extension wing
Forum topic by phlyers posted 08-26-2013 10:46 AM 1490 views 0 times favorited 6 replies Add to Favorites Watch
View phlyers's profile
phlyers
93 posts in 1662 days
08-26-2013 10:46 AM
Do people typically make a removable router fence if they’re going to incorporate the router on the TS extension wing or is it easier to just incorporate it in the TS fence? I guess what i’m saying is I want to add a TS wing and get a router lift but also need the fence to be removable due to the face that I sometimes use my TS rip capacity a lot which is 40”
Thanks in advance
View Woodbum's profile
Woodbum
800 posts in 2940 days
#1 posted 08-26-2013 12:47 PM
Speaking only from personal experience, I have a left mounted router table wing mounted to the stock left wing on a Griz 1023 with a Woodpeckers PRL V2 lift. I have an Incra TS III fence on the saw that I use for the router table too. For more complicated tasks I use the TSIII with an Incra Wonder fence attachment. This setup works well for me, and I can lower most bits below the table surface when not being used and put in a solid ring/plate on the lift and get the entire width of the wings for TS functions. IMHO, two fences would be too much to keep up with.
-- "Now I'm just another old guy wearing funny clothes"
View Kaleb the Swede's profile
Kaleb the Swede
1800 posts in 1844 days
#2 posted 08-26-2013 01:05 PM
Phylers I don’t know if you are a member of online fine woodworking.com but there was a guy there that had a good solution and some plans for that. He incorporated dust collection and everything. It’s only 5 bucks a month.
-- Just trying to build something beautiful
View doubleDD's profile
doubleDD
7022 posts in 1918 days
#3 posted 09-04-2013 01:28 AM
Here’s what I did 19 years ago on my last table saw and installed the same on this one when I bought it. I use the ts fence for the router table. It is easily removed in 20 seconds with a couple of screws, but it just stays on all the time now. I made the opening wide enough for the biggest of raised panel bits.Check photo.
If I need the ts in a hurry while routing I just lower the bit. I also built a dust box underneath the table with a 4’’ dust port to suck out the shavings. I don’t connect the 2 1/4’’ one any more. Hope this helps some.
View HorizontalMike's profile
HorizontalMike
7730 posts in 2789 days
#4 posted 09-04-2013 02:08 AM
Not cheap, but I love it.
This is my Grizzly #T10222 Router Extension Table for my Table Saw
phlyers
#5 posted 09-04-2013 03:19 AM
Nothing fancy but this is what I ended up doing. It’s just 3/4” MCP with some pine edging. I can easily remove the top by removing the lag bolts from underneath if ever need be. The Vega fence came with metal plates that mount to the bottom of the rails making this project easy. The router plate on that Bosch table will eventually make it’s way to this new extension saving some space. By the way if anyone is considering a new fence look at the Vega. Everything about it is heavy duty and it hasn’t failed me yet in terms of repeat ability.
View timbecht's profile
timbecht
13 posts in 1729 days
#6 posted 09-20-2013 06:18 PM
yeah i have a ryobi rts 16 table saw and am going to mount it on a roll around stand and include a rounter table to it will post pics when i get it done
