Cutting a Door to make a workbench top- advice
Forum topic by Jim100percent posted 08-26-2013 08:29 AM 7038 views 0 times favorited 13 replies Add to Favorites Watch
View Jim100percent's profile
Jim100percent
4 posts in 1644 days
08-26-2013 08:29 AM
Topic tags/keywords: question
Hello, everyone. First time poster, long time lurker. And thank god I did lurk; I’ve found tons of great tips here, tips that saved me a bunch of time and mistakes. So, thanks for that! (I’ve also caught your handplanes bug. A year and a half ago I owned one cheapo block plane. Now I own three, plus an old Stanley and a new Stanley Jackplane, plus an antique shoulder plane. Now whenever we go antique-hunting / flea marketing I am obsessed with old tools. Just rescued a bunch of old hand tools from my Dad’s basement (Grandpa and Great Grandpa were woodworkers as a hobby). Bits and braces… push drills… and Grandpas old block plane (a cheap model, but sentimental) Maybe there is a vaccine / treatment for this obsession?
OK, so my next project will be a workbench. As I said, there has been tons of great information I’ve gotten from here. I had planned on using 2 thicknesses of 3/4” plywood laminated together, but someone mentioned going to Habitat for Humanity and finding a used solid-core door (I had considered that already, but new they were too expensive). Great suggestion, found a monster 3’0” x 6’7” 1 23/32” thick industrial door. It’s already drilled and had a lockset- already removed. Now I need to cut it down to fit the space I have.
I have two questions, first am I better off cutting it to size with my old (It was my dads, so like 25 years old at least) Black and Decker circular saw (with a new blade) (with a piece of blue foam board underneath) or with my Ridgid 4512 Tablesaw with a freud combo blade? I don’t have an outfeed table (the new bench will be sized appropriately so that I can use it for that), but I do have a roller support (and a wife for extra hands). I am concerned that I may need to make two passes to cut through the monster (FYI its core is USB-like chips pressed and glued)- should I plan on two passes, or just try one?
Second, is there any easy way to avoid chip-out? Will just putting masking tape along the cutline work? Should I score the cut line with a razor or with a 1/8” pass of the saw? I am hoping to make this bench look as nice as I can.
For more info: I am a novice: I’ve built lots of Adirondacks, an oak Morris Chair (that turned out amazing), a couple of porch-swings, and some frames. My TS is new (and I love it- especially for the price). I go slow in order to avoid any mistakes. As my grandma used to say: “The hurrier I go, the behinder I get.”
I already have the vise hardware purchased, and can’t wait to get it all together. Thanks for any advice y’all can give!
13 replies so far
View grizzlymunchin's profile
grizzlymunchin
47 posts in 1651 days
#1 posted 08-26-2013 08:33 AM
I bought a solid core door from Lowes for like 58.00 it makes a nice top very solid and used 2×6 for the legs rip them on the tablesaw and get the rounded corners off use mdf for shelves and you will have a great flat bench
-- woodshop by the cornfeild
View firefighterontheside's profile (online now)
17572 posts in 1765 days
#2 posted 08-26-2013 12:47 PM
If you need to cut the table narrower, you can do that on the TS if you use the roller and assistance. You shouldn’t have any problem with tear out on that cut and can do it with one pass. For cutting it to length you will need to use the circular saw. Tear out will happen on the top side as you cut so put the side that you will use as the top of your bench down. Set the depth of your saw to be only about an eighth deeper than the doors thickness. On the top side you can use a knife to score the line first to help prevent tear out. Use a level or some other straight edge clamped to door so that as you run the saw base along it the blade cuts the line you want.
grizzlymunchin
#3 posted 08-26-2013 01:01 PM
ok
View Lee Barker's profile
Lee Barker
2170 posts in 2759 days
#4 posted 08-26-2013 02:48 PM
Alert: philosophical intervention ahead.
Grizzlymunchin: Your bench will be a tool, and a dandy one, but trying to keep it furniture-like will only make the construction more frustrating and needlessly complex.
Furthermore, if it comes out perfect, you won’t want to pound on it or scratch it. It will become a useless fixture.
My counsel: Determine the things it must be: flat, the right height, etc. Then build it, knowing that errors, as they come, will be great teachers and will enhance the quality of the projects you make which, unlike the bench, will leave the shop.
If you really enjoy building this bench you will likely build a second one, perhaps years from now, and you’ll fondly incorporate improvements and perhaps innovations we will all want to adopt.
Let this project be a freeflowing expression of your joy in woodworking, resulting in a tool that serves you loyally.
Kindly,
View MT_Stringer's profile
MT_Stringer
3154 posts in 3139 days
#5 posted 08-26-2013 03:40 PM
I was given a door like that. So heavy I couldn’t pick it up by myself. No way I would attempt to cut it on a table saw.
I cut mine to size with a circ saw with a guide so the cut would be straight. The blade used is the Freud Diablo 60 tooth available from HD for about $20. Makes a smooth cut.
I laminated the top with white Formica and used oak edge banding.
Hope this helps.
Mike
MT_Stringer
#6 posted 08-26-2013 04:31 PM
Check out my workbench project. The table is rock solid. The top is so heavy, it just sits on top. :-)
Note: I made my own leg levelers. Still work great over a year later.
Edit: @Jim. After re-reading your post, I though I would add a comment. I used my circular saw to cut all four sides. The important thing is to check your circular saw saw to make sure the bed is 90 deg to the blade. My old saw had been dropped and misused (by me) for many years so I bought a new Makita and it worked great for cutting the table top.
Since that door is probably like mine (check the pics), it should be a smooth cut on your table saw if you so desire. I would cut it to the approx length first so you don’t have additional weight to deal with. I still feel uneasy about you trying to cut it on your table saw without a lot of support otherwise it could become unwieldy and possibly get someone hurt if the blade binds and kicks back at you…or your wife.
If you do decide to use the table saw, make your first rip a little wider than desired, flip it around and then rip to the final width so you will have two smooth sides. You will still probably have to use your circular saw to cross cut the ends because it would be hard to do on your TS.
Good luck.
Mike
Jim100percent
#7 posted 08-27-2013 08:30 PM
Thanks for the info everyone, it is helpful. I need mine to be mobile, so casters are in order, but I also like the idea for leveling feet.
So many choices…
View cabmaker's profile
cabmaker
1694 posts in 2717 days
#8 posted 08-27-2013 09:52 PM
Why not use your table saw? As stated may become un weildy and contribute to kickback? Kickback will be of little or no concern, come on now, 1.5 hp with a 110lb door in its clutch?
Cut full depth. You do not have an out feed table so just run it halfway until its balanced then walk around to the out feed side and pull it the rest of the way.
JB
Lee Barker
#9 posted 08-27-2013 11:47 PM
Wax the saw table first. Really well.
Kindly,
View tedmuss's profile
tedmuss
3 posts in 1760 days
#10 posted 08-28-2013 05:35 AM
Put a straight edge across the width of the door. Often the particleboard core will swell a little more than the stiles and rails – it may not be flat (I work for a door manufacturer – we fight this every day). That being said – I have a solid core door as my workbench and it’s great. If you can find a strand composite lumber core (if you cut it open, it looks like really good osb plywood) or stave lumber core (kind of looks like butcher block) those work even better. They are more stable than particle board and aren’t as punky.
As far as cutting it, I would definitely use a circular saw and a straight edge. Score first, sharp blade, pink foam board underneath, two passes. Depending how much your cutting off, maybe give it a trial run before you get to your real line – we all learn from trying. good luck
Jim100percent
#11 posted 08-28-2013 11:40 AM
Tedmuss,
It’s strandboard, not sawdust, so I’m good there. I am also thinking that a test cut is in order, and a circular saw with my straightedge / clamp will enable the safest and easiest cut. I’m in no hurry, so a couple of extra cuts and a couple of extra passes won’t hurt!
Jim
Jim100percent
#12 posted 09-04-2013 01:32 AM
So, update: I did use my circular saw on styrofoam. Used a new 60 T fine finish 7 1/4 blade- came out perfect.
Turns out it is sawdust on the inside, only about an inch of strandboard on the ends. I’m not terribly worried, I’m gonna wrap the edges with 1 X 6 maple anyway, now I just need to figure out how to attach it… lots of glue and LONG screws- with deep coarse threads is what I’m thinking. Maybe pocket screws from the backside? It’ll need bracing, I’m sure.
View petersonmurdock's profile
petersonmurdock
11 posts in 1488 days
#13 posted 01-09-2015 03:14 AM
Several old and partially broken doors I have in my garage, I have replaced them to the old stock but good condition that I got from a door shop near us. Maybe I could turn something new with my old broken ones to stuff like this. Thanks to the idea.
