Belt sanders? Your thoughts
Forum topic by Kaleb the Swede posted 08-26-2013 12:57 AM 2006 views 0 times favorited 42 replies Add to Favorites Watch
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1992 days
08-26-2013 12:57 AM
Topic tags/keywords: question sander
Hi there. I am asking out of ignorance with this question. I have two sanders, a random orbit sander and a quarter sheet. I have a nice collection of hand planes a 4 through 7. Is a belt sander ( the handheld kind) an essential for an aspiring (wannabe) woodworker. What are it’s uses? With my hand planes and sanders i have now, do i need it? The reason I am asking is I was taken with the new rigid belt sander and I was kicking around the idea of getting it. Do I need it? Or is it just the tool junkie in me? I genuinely would like to know from the guys who use them. We talk a lot about tools, I was just wondering about them as they aren’t brought up much.
-- Just trying to build something beautiful
42 replies so far
18351 posts in 1880 days
#1 posted 08-26-2013 01:18 AM
I just bought that new ridgid sander. I had an old old one that had been my grandpas. I don’t use one for fine sanding, but more for removing material such as when fitting a built in cabinet. I scribe the shape onto the piece and then sand to the line. I don’t have any kind of fixed tabletop sander so I will turn it upside down and lock the trigger and then I can just hold the piece on top of the sander. Its nice to have.
View Grandpa's profile
Grandpa
3259 posts in 2699 days
#2 posted 08-26-2013 01:25 AM
I own 2 belt sanders and have taught woodworking to adults in even classes. Many nice projects have been ruined by using belt sanders. I would never say don’t get a belt sander. I would say learn to use one properly and gently. They can be very useful but use with caution.
View BentheViking's profile
BentheViking
1782 posts in 2587 days
#3 posted 08-26-2013 01:27 AM
Do you need it maybe maybe not. Are you going to find times its useful, if not for fine woodworking at least for some other household task? Yup. Are you going to find some time within the first week of owning it that you can do something useful with it so that you can say “look honey this new thing isn’t a waste”? Almost definitely.
Glad to see your back from the sea. How was your deadliest catch summer?
-- It's made of wood. Real sturdy.--Chubbs Peterson
View distrbd's profile
distrbd
2252 posts in 2470 days
#4 posted 08-26-2013 01:29 AM
Kaleb it’s the tool junkie in you wanting a new tool lol..but I must also add that if you are impatient and want to flatten a wooden surface quickly ,nothing removes wood faster than a belt sander,if you need to round a table top corner or straighten an edge fast,then you may find a use for it in your shop.
On the other hand if you enjoy working with hand planes and are good at it,a belt sander will be sitting in a box and not get much use.
If you ask me,buy one.
-- Ken from Ontario, Canada
Kaleb the Swede
#5 posted 08-26-2013 01:43 AM
Thanks for the responses guys. Thinking I may get one. Ben it was a grind this summer. I was only home 3 days in July.
View Loren's profile
10476 posts in 3671 days
#6 posted 08-26-2013 01:46 AM
They have their uses. Scribing back splashes is one. Leveling
inset shaker drawer cases is another.
Sanding boards and panels flat with a hand held belt
sander requires some practice and is certainly unforgiving
of attention lapses.
Kaleb the Swede
#7 posted 08-26-2013 03:04 AM
Thanks Loren. I just never thought about one much. I watched Norm use it. I just thought their may be a few applications where it could be useful.
View redSLED's profile
redSLED
790 posts in 1916 days
#8 posted 08-26-2013 03:33 AM
I’m mostly a power tool user, and my Makita 4”x24” belt sander (BS) is in my top 5 favourite tools because I can get quite a few things done with it very quickly when I need to. I’m planning for a 2nd BS (cheaper and new) so I can run a finer grit belt right after a coarse one without having to switch belts on the same BS.
Uses and benefits:
- sand away rough cuts and saw blade burn marks fast (if no router/table is set-up for milling)
- sand down knots fast and flat
- remove patches of old paint/clear coats fast
- even out/make flush slight glue-up mistakes
- take 1/16” off soft wood fast if piece/board is not too big (even removal requires skill!)
- fast wood removal as desired prior to ‘distressed finishing’
- shape a radius on a corner really fast (skill required!) vs jig saw/file and sander
- flip BS upside down to:
—sand fast and flat small pieces/edges
—use belt end(s) for quick contour/spindle sand
—quick sharpening of pencils, plumb bob, beater chisels, scribes/awls/punches, etc.
—quickly sharpen drill bits instead of throwing them away (titanium coated not applicable)
—make and shape any size wood plugs and dowels fast from scraps
Clearly, without my handheld belt sander I’d be walking the streets aimlessly late at night.
View Moron's profile
Moron
5032 posts in 3917 days
#9 posted 08-26-2013 03:37 AM
easiest tool to ruin a lot of hard work
avoid all “green “ people who think they know how to use one
a necessary tool in my arsenal that I don’t lend out due to catastrophic results
View tefinn's profile
tefinn
1222 posts in 2460 days
#10 posted 08-26-2013 03:50 AM
As already mentioned, I use mine for sanding scribe lines. I also use it for sanding ill fitting doors in the house, fast initial sanding of cutting boards and taking off paint or cleaning up reclaimed lumber before planing.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
redSLED
#11 posted 08-26-2013 04:07 AM
^ Moron, too true. I also would never lend out my belt sander – but because I use it often.
Moron
#12 posted 08-26-2013 04:14 AM
if you dont own one, buy one
it will teach you faster then you care to learn
its clear to me, that sanding etiquette isnt sold
its earned
Moron
#13 posted 08-26-2013 04:21 AM
sanding is a never ending pursuit of lowering and raising the bar of a goal that each individual sets ?
View mbs's profile
mbs
1656 posts in 2963 days
#14 posted 08-26-2013 04:28 AM
I haven’t used my belt sander since I purchased the Festool rotex sander which is probably 10 yrs ago.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View Christophret's profile
Christophret
150 posts in 2025 days
#15 posted 08-26-2013 04:47 AM
I want what Moron is taking.
-- I cut it twice and it's still too short!
showing 1 through 15 of 42 replies
