How to finish mahogany on a garden bench.
Forum topic by Emma Walker posted 08-25-2013 05:58 PM 2862 views 0 times favorited 21 replies Add to Favorites Watch
View Emma Walker's profile
Emma Walker
560 posts in 1983 days
08-25-2013 05:58 PM
I got a pair if cast iron garden bench side from an old garden bench. I had them sandblasted and powder coated. I’m replacing the wooden slats with mahogany. I need to know what the best way is to finish these mahogany slats. I want to bring out the dark color of the mahogany while also making it as resistant as possible to Wisconsin weather.
-- I'm a twisted 2x4 in a pile of straight lumber.
21 replies so far
View Bill White's profile (online now)
Bill White
4820 posts in 3833 days
#1 posted 08-25-2013 06:06 PM
Good luck!
ANY finish used outdoors will have to be renewed often. There are those who would suggest a marine varnish, but even that would have to be touched up.
Oil? Could be, but maintain often.
AFAIK, ain’t no fool proof exterior finish that wouldn’t need the care.
Kinda like a deck.
Bill
-- bill@magraphics.us
Emma Walker
#2 posted 08-25-2013 06:17 PM
Could I bring out the color using BLO and then put something like Tompsons Water Seal over the top of it?
View Jesse.R's profile (online now)
Jesse.R
55 posts in 2797 days
#3 posted 08-25-2013 06:21 PM
any exterior oil based finish will bring out the color just fine. if its going to be out in the weather theres no way around needing to refinish it periodically. about once a year.
-- jesse
View mesquite22's profile
mesquite22
42 posts in 2541 days
#4 posted 08-25-2013 07:25 PM
http://www.hempshield.net/ this works well
View Don W's profile
Don W
18561 posts in 2440 days
#5 posted 08-25-2013 09:51 PM
Marine Varnish over BLO.
View Roger's profile
Roger
20897 posts in 2676 days
#6 posted 08-26-2013 01:05 AM
I like thinned out BLO to help the grain pop a bit. The top coat should be something for the outdoors for sure. Good luck with your project. I’m sure it’ll be awesome
View Dusty56's profile
Dusty56
11814 posts in 3560 days
#7 posted 08-26-2013 01:26 AM
Thanks for asking the question, Emma : )
That hempseed oil looks pretty promising…thanks, mesquite22 : )
Emma Walker
#8 posted 08-26-2013 11:57 AM
Don W
By “Marine Varnish over BLO” do you mean Marine Varnish instead of BLO or BLO first and then Marine Varnish?
Don W
#9 posted 08-26-2013 12:44 PM
BLO first and then Marine Varnish. BLO will bring out the grain. Marine Varnish will protect it.
View LakeLover's profile
LakeLover
283 posts in 1812 days
#10 posted 08-26-2013 01:42 PM
If you are bolting the wood to the metal. Make sure you seal the holes. Put something between the metal bases and wood.
Emma Walker
#11 posted 08-26-2013 02:40 PM
LakeLover,
like a nylon washer?
Emma Walker
#12 posted 08-26-2013 04:43 PM
Could I add just a pinch of stain to thinned out BLO to help darken the wood? Like maybe a table spoon to a 12 oz mixture of BLO and mineral spirits.
Don W
#13 posted 08-26-2013 05:44 PM
If you want to darken it, I’d use a colored Danish oil instead of BLO. Pick your color.
Emma Walker
#14 posted 08-26-2013 06:53 PM
Thanks Don,
I picked mahogany because it’s most resistant to mold and bugs but I was surprised at how light colored it is.
View ScaleShipWright's profile
ScaleShipWright
253 posts in 1758 days
#15 posted 08-26-2013 07:20 PM
Hi Emma, it’s nice to have you back in LJ.
I second Dan’s suggestion about Danish oil to darken wood. BTW I have found an article in Fine Woodworking about outdoor finish; the author suggests the use of an epoxy sealer under marine varnish to obtain a more durable finish:
http://www.finewoodworking.com/item/13849/the-ultimate-outdoor-finish
Alessandro
-- God exists... But relax, He's not you!
