End connection
« back to Joinery forum
Forum topic by Howie posted 08-25-2013 03:28 PM 1163 views 0 times favorited 11 replies Add to Favorites Watch
View Howie's profile
Howie
2656 posts in 2828 days
08-25-2013 03:28 PM
I recently aqquired and enormous stack of oak . 1×4 x…...29 inches.(probably 7-800 pieces!)
Question, would using box joints on each end to join them together ( in the middle) be a good way to connect them end to end? This would make them long enough to use for a blanket chest.(40”) Then they would be edge glued for a large panel.
I’ve already made raised panels and used rail and stile (20×17) but would like to try something else as I’m concerned about the cross grain issue.
Any suggestions?
-- Life is good.
11 replies so far
View JustJoe's profile
JustJoe
1554 posts in 1943 days
#1 posted 08-25-2013 03:34 PM
Do you mean joining end-grain to end-grain? If so, and they’re less than 1.5’ thick, you can use a finger-joint bit like this one:
http://www.rockler.com/product.cfm?page=5710
The bit is made for just that purpose. There is probably a bigger, meaner looking shaper cutter that would do even thicker pieces of lumber.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View Joe Lyddon's profile (online now)
Joe Lyddon
10038 posts in 3957 days
#2 posted 08-25-2013 03:52 PM
I think I would think the Dovetail joint would be better…
... or stagger Butt joints like in flooring…
7-800 is quite a range… I hope you have more toward 800 than just 7… :) LOL (kidding)
Sounds like you made quite a HAUL!!
View johnstoneb's profile
johnstoneb
2789 posts in 2078 days
#3 posted 08-25-2013 04:00 PM
+1 Just Joe’s suggestion will be a much stronger joint.
-- Bruce, Boise, ID
View ITnerd's profile
ITnerd
263 posts in 2505 days
#4 posted 08-25-2013 05:14 PM
+1 to JustJoes suggestion, if you’re looking to get longer pieces than the 39” you’re starting with. It will provide the best cross-section for gluing, and will be as strong as the wood if done properly.
It will also look like a butt joint from front or back, which would be less distracting (visually) across the front and sides of a blanket chest than box joints or dovetails, in my opinion.
Nice job with your haul,
Chris
-- Chris @ Atlanta - JGM - Occam's razor tells us that when you hear hoofs, think horses not zebras.
View Dallas's profile
Dallas
3599 posts in 2392 days
#5 posted 08-25-2013 05:37 PM
The easy way is to cut a bevel with a mild angle across the end of the boards. Turn one up, turn one down, slide them together to meet and glue/clamp.
As long as it’s not structural it will be plenty strong.
edit
If you need more strength than that, put a pair of dowels through the glued up boards.
View pintodeluxe's profile
pintodeluxe
5566 posts in 2718 days
#6 posted 08-25-2013 05:53 PM
Box joints, finger joint bit at the router table, or flat dovetails will all work.
116905 posts in 3482 days
#7 posted 08-25-2013 06:38 PM
Finger joints are the standard joints for joining pieces end to end as Joe stated.
Howie
#8 posted 08-25-2013 08:04 PM
I contemplated the finger joints but I was thinking about cosmetics. Since I have the wood (:-)) I think I’ll give the dovetails a try and see how it looks. If I don’t like it I’ll go with the finger joints.
@Joe, I would say there is easily 800. This is on a double pallet (four stacks) and the nice thing is my BIL is storing most of it in a dry trailer. I hauled enough back from Indiana last month to do me for a while and he will bring the rest when he “snowbirds” in November.
-- Life is good.
View Woodendeavor's profile
Woodendeavor
276 posts in 2512 days
#9 posted 08-25-2013 11:26 PM
Turn it into a design feature. Chamfer the ends slightly to show the joint. Then cut a slot into the end of the board and glue together with a plywood spline. You could also do this edge to edge off setting the butt joints making your front back sides and lid
404 - Not Found
2544 posts in 2874 days
#10 posted 08-25-2013 11:35 PM
+1 on Joe. Finger joint the ends but stagger the joints when you are gluing up the panels. Lots of manufactured furniture is done this way. There is another cutter where the fingers taper to a v but it is still essentially a finger jointer bit.
View Split's profile
Split
33 posts in 1644 days
#11 posted 08-26-2013 07:54 PM
The problem with box joints is that the stability relies on the 90 degree angle. They push into each other. I realize you would use glue but they may tend to almost warp in and out. I would recommend domino joints if your doing long end to end. If your doing short end to end done tail provides extra support as they are angled. I would put the smaller portion of the angle in wards. Dallas also have a good idea with perhaps two 45 cuts that fits together but relies on glue for strength. You could use dowels with a jig but doing so can be odd in end grain. I would do a tongue and groove joint. This is strong does not allow for too much forward backward movement and appears seamless. I hope this helps.
