3/4" vs 20mm
Forum topic by JimNEB posted 08-25-2013 02:33 PM 5005 views 0 times favorited 14 replies Add to Favorites Watch
View JimNEB's profile
JimNEB
239 posts in 3064 days
08-25-2013 02:33 PM
Topic tags/keywords: shop upgrades question mft
I’m looking at building a new work table and trying to decide on weather to go with 3/4” holes on a 4” grid or the 20mm holes on a 96mm grid. Any thoughts, pros and cons would be welcome.
Thanks
-- Jim, Nebraska
14 replies so far
View MT_Stringer's profile
MT_Stringer
3168 posts in 3227 days
#1 posted 08-25-2013 02:50 PM
Jim, have you seen the Ron Paulk workbench video?
JimNEB
#2 posted 08-25-2013 07:19 PM
MT-That was what got me thinking about putting a grid on it. I’m just not sure weather to go 20mm or 3/4”. I don’t know if it will even make a difference.
-- Jim, Nebraska
View Loco's profile
Loco
210 posts in 1745 days
#3 posted 08-25-2013 07:37 PM
You going to use wood dowels as pegs or aluminum ( the correct way) ?
I’d use a 13/16 spade bit( take a belt sander to a 7/8 bit if you want it tighter) and buy 20 MM aluminum rounds.
Here. I’ll save you some time ;-)~
http://www.orangealuminum.com/round-rods.html
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
MT_Stringer
#4 posted 08-25-2013 08:07 PM
@Jim – How thick will your table be?
My table is 2 inches thick and has some 3/4 inch holes drilled in it. The Festool style clamps will not fit through the holes because of the thickness.
The work area of my miter saw station has 3/4 inch holes drilled in it. The clamps work just fine. The clamps I am using are the ones that are part of the track saw package from Grizzly so they are doing double duty for me. :-)
10380 posts in 3643 days
#5 posted 08-25-2013 08:16 PM
I built a fixture table for bending. I used 7/8” holes on 4”
centers. 1/2” pipe will fit in 7/8” holes. I welded washer
flanges onto short lengths of pipe. A 1/2” bolt can be put
though to clamp the pipe down if needed.
JimNEB
#6 posted 09-09-2013 07:42 PM
Good ideas…
I ‘m thinking of laminating a piece of 3/4” mdf and 1/2 mdf for the cabinet top with about a 4” area underneath that I can use as a downdraft table also.
I’ve been looking at some of the products from qwas corp to use with my table…
-- Jim, Nebraska
MT_Stringer
#7 posted 09-09-2013 07:55 PM
“I ‘m thinking of laminating a piece of 3/4” mdf and 1/2 mdf for the cabinet top with about a 4” area underneath that I can use as a downdraft table also.”
Jim, i am not sure if the Festool style clamps will work on a table thicker than 3/4 inch.
View Dutchy's profile
Dutchy
2919 posts in 2164 days
#8 posted 09-09-2013 08:02 PM
Why don,t you do both. To me it likes possible.
-- https://dutchypatterns.com/
JimNEB
#9 posted 09-09-2013 08:07 PM
Thanks Mike, I didn’t know that. Gives me something to consider.
-- Jim, Nebraska
JimNEB
#10 posted 09-09-2013 08:10 PM
Dutchy, my Dutch is non-existant. I do know a smattering of German though.
I hadn’t thought of doing both, nice idea. I’ll look into how that might work.
Thanks
-- Jim, Nebraska
View gtbuzz's profile
gtbuzz
427 posts in 2437 days
#11 posted 09-09-2013 08:17 PM
I’m kind of in the same boat as you. Looking at building a table that’s compatible with the 20mm MFT dogs that I’ve got, but I don’t really want to go all 20mm since it’s harder to find stateside and can be quite expensive compared to the 3/4” stuff.
The idea that I’m leaning towards right now is alternating rows of 3/4” and 20mm holes. The grid will be based on imperial units rather than metric though. I figure it would be really wonky to have rows where the centerline doesn’t quite line up.
MT_Stringer
#12 posted 09-09-2013 11:15 PM
I would like to see pics of what y’all come up with. Since my table is almost 2 inches thick, I drilled out the useless 3/4” holes with a 7/8 inch bit. I haven’t had the need to use them yet but could change shortly. I have some 1/2 inch Bessey pipe clamps. The 1/2 inch pipe will fit through the hole. Also, I have several of th drill press vie grip type clamps. Ace hardware had some 12mm threaded rod so I bought a couple couplers and the rod. Now I can set the clamps up in any of the holes for assembly jobs.
Another option is to cut the knob off the end of f style bar clamps and insert part of it up through the table from the bottom and mount the clamp handle on it.
My miter saw station has the 3/4 inch holes and the clamps really work well. Need to use the pocket hole jig. No problem, just clamp it in place and git after it!
Dutchy
#13 posted 09-15-2013 09:16 AM
Gutentag Jim,
I don,t know if you are still thinking, but maybe you are happy with this drawing:
Please let me know If you like a auto CAD drawing.
Succes
JimNEB
#14 posted 09-15-2013 02:05 PM
Dutchy,
I like that thanks!
-- Jim, Nebraska
