Arbor/Assembly Router Bit Help
Forum topic by Matt Michaud posted 08-25-2013 01:08 PM 967 views 0 times favorited 7 replies Add to Favorites Watch
View Matt Michaud's profile
Matt Michaud
35 posts in 3087 days
08-25-2013 01:08 PM
So I have a flush-cutting task that has a tendency to split when I reach the end grain (a common problem well explained here: http://lumberjocks.com/Jcw0013/blog/30963). Normally I can control this by climb-milling and other tricks, but this is an extremely hard wood that is being stubborn. Since I use a shaper which has a “reverse” switch, I was thinking of simply switching directions (same as flipping part and template over). Here is where I am stuck: I want to stick with router bits, not shaper bits so that I don’t need to constantly change spindles. I know some router bits, like slot cutters, have an arbor. I have never used one, but it seems like this cutter could be flipped, allowing me to cut in reverse. The problem is that any arbor-ed bits I have seen have very large diameter cutters, meaning I would need an equally large diameter bearing for flush cutting. Does anybody know of a relatively thick (so I dont have to stack a ton), small diameter (3/4”?) cutter that installs on an arbor?
My backup option is a reverse flush-cut bit – I have seen these in spiral bits, but never with a bearing.
-- "Strength in Composites" http://sandwichtechskis.com/shop-dust-collection.htm
7 replies so far
View Nicky's profile
Nicky
695 posts in 4113 days
#1 posted 08-25-2013 05:10 PM
Is this the type?
http://www.amanatool.com/routerbits/47170-ez-change-ocemco-system-TA-150.html
This one may not have the height you’re looking for, but I’m curious if its the type of solution you’re after.
-- Nicky
Matt Michaud
#2 posted 08-25-2013 05:41 PM
Awesome find. That would work great IF its flip-able. One end looks like it keys over the lower hex. Regular slot cutters don’t need to key on do they? Do the cutters tend to slip otherwise?
View pintodeluxe's profile
pintodeluxe
5701 posts in 2835 days
#3 posted 08-25-2013 05:48 PM
On tricky template routing projects I have found it helpful to bandsaw fairly close to the cutline. Then I refine the profile very close to the line with a belt sander. By the time I am routing, I am only removing 1/16” of material.
A climb cut might even be safe, since so little material is being removed.
Best of luck.
Nicky
#4 posted 08-25-2013 07:39 PM
I just looked at my slot cutter, no index key, seems I can flip the cutter.
I’ve been faced with similar cuts and now use shear-cut bits (on router, don’t have a shaper anymore.)When I do pattern route, I really do try to minimize the material I need to remove, and as Willie mentioned, climb cut.
-- Nicky
Matt Michaud
#5 posted 08-25-2013 08:27 PM
Nicky, thanks for checking that for me. Are you using shear/straight bits or spiral? I have read claims that the spiral bits will prevent splitting, but I am skeptical. I have had good luck with the climbing on maple, but this is ipe (extremely hard) making a sharp corner – so climbing is really tough to control.
Nicky
#6 posted 08-25-2013 09:00 PM
I have both.
The spiral bit is http://www.amazon.com/CMT-191-507-11b-Double-Bearing-2-Edge/dp/B001FD8LIO
The shear-cut is Freud 42-204 3/4-Inch Down shear Helix Flush Trim Bit
The spiral bit, by far leaves a smoother cut, and less blow-out on end grain, but it’s almost 3x the price of the Freud down-shear. I use the spiral bit mainly for pattern routing using ebony (Greene and Greene accents.) I occasionally have some blowouts, but its the best method that I’ve come across to minimize problems.
The down-shear is great for trimming edges on long grain. Mixed results on end grain, but better then a standard straight bit.
-- Nicky
Matt Michaud
#7 posted 08-30-2013 06:24 PM
Precisionbits.com sold me the rabbet cutter and arbor for $15.
I heart them.
