Rip cut 2x4 into 2 1x4's with table saw
Forum topic by DaveNJ posted 08-24-2013 08:31 PM 13161 views 0 times favorited 16 replies Add to Favorites Watch
View DaveNJ's profile
1 post in 1671 days
08-24-2013 08:31 PM
Topic tags/keywords: rip cut jig tablesaw
I would like some advice on rip cutting a 2×4 (4 ft. long) into two 1×4’s using a table saw. I have a home-built sled with clamps to hold down the lumber and keep my hands far away from the blade.
My question is—if I cut half way through and then flip the board and do the other half, is this kind of a cut (only half way through) likely to cause kickback?
Thanks for the advice.
16 replies so far
View johnintecumseh's profile
125 posts in 3349 days
#1 posted 08-24-2013 08:46 PM
If you flip and get the same side on the fence, go slow (very at the end) , when it cuts thru, hold it on the fence and turn the saw off. small mark left by the blade. keep smiling John
-- retired and smiling
View MT_Stringer's profile
3160 posts in 3163 days
#2 posted 08-24-2013 08:48 PM
I think others will chime in with the same thoughts.
Make your first rip a little less than half of the thickness. Then flip end for end and do it again.
Complete your cut with a hand saw.
Hope this helps.
View brtech's profile
1027 posts in 2855 days
#3 posted 08-24-2013 09:19 PM
You understand that after a couple of days, the 1×4s are likely to resemble pretzels, right?
If you start with KD 2×4s, it won’t be as bad, but the inexpensive ones warp pretty fast when you make a cut like that.
View Woodmaster1's profile
905 posts in 2519 days
#4 posted 08-24-2013 09:39 PM
I would go buy a 1X 4 they are cheap and safer than ripping a 2×4 on the table saw. You will also have less of a chance of them warping.
View grizzlymunchin's profile
47 posts in 1675 days
#5 posted 08-24-2013 11:02 PM
yep they will go pretzel quick unless your going to glue them dowm soon as you cut them
-- woodshop by the cornfeild
Shawn Masterson
1324 posts in 1881 days
#6 posted 08-24-2013 11:11 PM
I just finished resawing 33 5/4” x 6” x 8’ cedar deck boards on the TS by just standing them up and running them through. no sled or other stuff to get in the way. the blade is buried I don’t see where the concern is, just watch your hand placement as the blade exits the wood. I needed 500+ 3/8” x 5” x 12” pieces to make diamonds, scallops, points, and dog ear siding pieces for a historic house I am working on. after resawing I had 7/16 left then I planed them down to the final thickness. what you are trying to do will work but you will not have 3/4 when you are done 1 1/2 – saw blade = 11/16 left. also the odds the board is straight enough that the saw blade meets in the middle is rare. so if you were making 5/8 stock you would be good.
View JustJoe's profile
1554 posts in 1970 days
#7 posted 08-24-2013 11:24 PM
2x lumber is the wettest thing the borg sells except for those sodas in the case next to the checkout stand.
So +1 to everyone who said “you can cut them but they will turn into pretzels.”
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View pete724's profile
53 posts in 741 days
#8 posted 04-01-2016 08:44 AM
Wait …........
2x box store lumber(studs) are actually 1 1/2 in wide correct?
1x is 3/4 in right?
Standard TS saw kerf is 1/8 in ??
Those 1x ’s are going to be missing 1/16 in in thickness because of the saw kerf even if you CAN resaw them right down the middle on a table saw.
IMHO “resawing on the tablesaw” is not the concern for kickback, but resawing crappy boxstore studs is the risk(of kickback/warping/twisting).
View KYSean's profile
119 posts in 3529 days
#9 posted 04-01-2016 12:57 PM
I would just buy the 1×4 ’s
View dhazelton's profile
2720 posts in 2229 days
#10 posted 04-01-2016 01:27 PM
Another first time poster with a question that’s – questionable. Who’s on a phishing trip here?
View hotbyte's profile
991 posts in 2908 days
#11 posted 04-01-2016 05:55 PM
Account was created in 2013…that’s really waiting on the bait to mature!
Now I remember why I never posted questions when I first joined LJ!
Another first time poster with a question that s – questionable. Who s on a phishing trip here?
- dhazelton
View ADHDan's profile
800 posts in 2041 days
#12 posted 04-01-2016 08:46 PM
If you have a riving knife (or can rig up a tall splitter) you’ll probably be fine. I’ve resawn a LOT of boards up to 6” wide on my table saw without having a single kickback scare, sawing halfway through and flipping them end-for-end. At first I was terrified, but once I got used to seeing the blade that high – and made sure I was using the right type of push stick/shoe and featherboards – I don’t really have any problems with it.
But as everyone else said, in this case just buy the 1×4s. For a few bucks extra you avoid the hassle and won’t end up with warped results.
-- Dan in Minneapolis, woodworking since 11/11.
#13 posted 04-01-2016 08:47 PM
Double post.
View gwilki's profile
192 posts in 1406 days
#14 posted 04-01-2016 11:30 PM
Since the question was asked, and 8 replies made in 2013, I would bet that he has cut them by now. :-)
-- Grant Wilkinson, Ottawa ON
View MrUnix's profile
6480 posts in 2131 days
#15 posted 04-01-2016 11:39 PM
- gwilki
That would be a good bet… particularly since they haven’t been back since asking!
