Grizzly Bandsaw Tension Knob
Forum topic by Donald's Woodshop posted 08-23-2013 11:11 PM 2053 views 0 times favorited 10 replies Add to Favorites Watch
View Donald's Woodshop's profile
Donald's Woodshop
111 posts in 2350 days
08-23-2013 11:11 PM
I got my new bandsaw earlier this week, a G0555LANV. After unpacking it I found that the plastic tension knob on top was shattered into 100 pieces. I contacted Grizzly about it and they are going to send me a new tension bolt. The part comes as the bolt and the knob. I believe this is because there is, or was, a hole in the side of the knob and a hole in the bolt. A roll pin joins them together. They are currently out of stock on the part but are trying to locate one. Since I am going to end up getting a new one does anyone have any ideas to make the tension knob, minus a knob, functional for the time being? I really want to get it all set up and running. It’s always exciting to get a new tool and sucks when it’s one piece of plastic that stops it all. Thanks.
-- Imperfections make it unique!
10 replies so far
View Bill White's profile
Bill White
5148 posts in 4197 days
#1 posted 08-23-2013 11:32 PM
When I have a Grizz prob, I often call on the TECH LINE, Those folks seem to have a way to circumvent the “parts aren’t available yet” network. Good folks, and will be eager to help out.
Bill
-- bill@magraphics.us
View kdc68's profile
kdc68
2692 posts in 2513 days
#2 posted 08-23-2013 11:47 PM
I own the G0555P model. Below is a quick photo of my tension knob. If your model is like mine, then your tension bolt is threaded like mine (knob has a fixed nut, screwed on the end of the tension rod and held in place with a pin). Maybe, you could temporarily replace the knob with two nuts tightened against each other onto the tension rod. Then use a socket and ratchet or box wrench to turn the two nuts to tension your blade…. just a guess…..Congrats on your saw regardless
-- Measure "at least" twice and cut once
Donald's Woodshop
#3 posted 08-23-2013 11:58 PM
Ya, that is what I can tell it is supposed to look like from the few big pieces I have. The nut idea is a good one. I might try that. I was able to get the roll pin out so I might try to find a new knob that will fit the threads. I will probably take the bolt off tomorrow and take it down to the big box store and see what they got. Fingers crossed.
kdc68
#4 posted 08-24-2013 12:06 AM
donaldmoran....Look at the Grizzly Website for your model. They may have a schematic of your saw under “Parts List”.....good luck !
Donald's Woodshop
#5 posted 08-24-2013 12:29 AM
Ya that is where I found the part number when I told them what I needed.
View JustaLilJoinery's profile
JustaLilJoinery
31 posts in 1992 days
#6 posted 08-24-2013 03:05 AM
Congrats on the new addition!
I guess I’m now in the G0555 club…I’m JUST about finished setting up having also just received my Woodslicer blade shipment recommended here
I was SO eager to cut something but then realized that when a friend’s hubby came over to help me get the saw upstairs, I was so worried about putting them out (they got NOTHING out of helping me) that I neglected to level the base on the wheeled base that came with. SO now that the saw doesn’t try to lean over me…I have to decide if I should just start cutting or bite the bullet and move the whole she-bang now that I realize how much the table and fence stick out into my walkway. (if you check out my blog here you’ll see that my ‘walkway’ in a 10’ room is very tongue in cheek.
One part wants to jump in and the other wants to be just ‘so’ before I get started…I totally sympathize with having to wait. Hopefully you can jig up a workaround and start having some fun.
Would love to see your first project!
-- Genius may have its limitations, but stupidity is not thus handicapped. -Hubbard
View Dorty's profile
Dorty
20 posts in 2689 days
#7 posted 08-24-2013 12:47 PM
There should be two sets of Jam nuts on the bolt. You can just use a wrench to tighten and loosen the bolt. Channel locks will work to:)
Donald's Woodshop
#8 posted 08-26-2013 01:54 AM
The solution! Temporarily that is.
kdc68
#9 posted 08-26-2013 02:21 AM
Great that you came up with a fix….now you can use the saw until Grizzly comes up with replacement parts
View Chris208's profile
Chris208
240 posts in 2506 days
#10 posted 08-26-2013 03:18 AM
Vice grips work great. I had them as the tension knob on my old bandsaw. Ghetto looking, but way easier to use than the standard knob.
