router armature
Forum topic by moobeast posted 08-23-2013 02:19 AM 1105 views 0 times favorited 5 replies Add to Favorites Watch
View moobeast's profile
moobeast
2 posts in 2160 days
08-23-2013 02:19 AM
The collet nut on my Dewalt 625 plunge router got cross threaded on the armature; armature threads are messed up some, collet nut threads are fine. Anyone ever use a die to fix something like this? A new armature is over a hundred bucks, I don’t use this router very often. Would anyone know what size these threads are? Thanks.
5 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2088 days
#1 posted 08-23-2013 02:07 PM
Well that’s a big pot of suckiness. I don’t know the size, but I know that bigger dies are harder to find than normal small bolt sizes. You might try and find a thread chaser or restoring file .
Good Luck.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View ChrisK's profile
ChrisK
1979 posts in 3132 days
#2 posted 08-23-2013 02:23 PM
Found this link from another forum for the same problem:
http://www.amazon.com/Nicholson-33024-Thread-Restoring-4-Piece/dp/B001T4KRHC/ref=sr_1_2?s=hi&ie=UTF8&qid=1324340406&sr=1-2&tag=viglink129418-20
The thread may be metric, you an use a caliper to measure the pitch. It is a fine thread and a die will be pricy. Try thread file to file away the damaged ares between the threads.
-- Chris K
View BBF's profile
BBF
143 posts in 1889 days
#3 posted 08-23-2013 03:04 PM
I would just use some needle files.
-- I've never been disappointed buying quality but I have been disappointed buying good enough.
View Loren's profile
10476 posts in 3698 days
#4 posted 08-23-2013 04:20 PM
I’d file it. Easier to do than you think. You may want to
buy some little files if you don’t have them. They come
in useful in other ways. I am sure that’s a metric tool
as it’s from Italy/Switzerland.
View Bluepine38's profile
Bluepine38
3379 posts in 3135 days
#5 posted 08-23-2013 05:05 PM
If it is just a small area, a small triangular file can do it, but if it is a larger area, I have always had better luck
with the thread files, they tend to set in the tool box a lot, but when needed, they are great to have.
