How to join long angle cuts.
« back to Joinery forum
Forum topic by Split posted 08-22-2013 03:11 PM 6054 views 0 times favorited 17 replies Add to Favorites Watch
View Split's profile
Split
33 posts in 1766 days
08-22-2013 03:11 PM
I am making a corner cabinet and I am having to rip two 45 angles And put one behind the other to make a 135 degree angle. Or if I am thinking correct I can use a 90 and a 45 degree cut to make the 135 degree angle. Either way I am unsure of how to join them as clamping would be near impossible. Biscuits will not be strong enough I don’t believe. Dowels will be too long. The material is 6 ft long and the angle has to go the long way so spline would be really odd. Any ideas?
Thanks
17 replies so far
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#1 posted 08-22-2013 03:53 PM
The joint on the right is a long 135 degree miter joint with biscuits. It went together great, and has held up perfectly over the past couple years. Is this the type of joint you are making?
Here is the project page…
http://lumberjocks.com/projects/51723
View yrob's profile
yrob
340 posts in 3679 days
#2 posted 08-22-2013 03:54 PM
Traditional corner cabinets with angles like that were assembled with splines. A groove would be made in each board and a hardwood spline inserted. It will hold together great. The racking forces on a cabinet are not that big.
-- Yves
Split
#3 posted 08-22-2013 05:06 PM
Pintodelux how did you get the biscuit cutter to long up with the angled corresponding pieces when making the slot?
pintodeluxe
#4 posted 08-22-2013 05:45 PM
I held the long miters together, and marked the biscuit locations. Then I used the fence on my biscuit cutter to stabilize the tool while cutting the slots.
Good luck
Split
#5 posted 08-22-2013 06:53 PM
Ok I will have to try it on some scrap pine before I try the proposed red oak. Thanks again. Oooo I was also thinking of using pocket holes but I don’t think they will reach to both materials without going through?
Split
#6 posted 08-22-2013 06:56 PM
As far as the 45 degree angles go do you cut them opposite and but them together so they don’t make a 90?
pintodeluxe
#7 posted 08-22-2013 07:26 PM
You always want to cut the same angle on both mating pieces. So you can rip the boards on the tablesaw at a 22.5 degree angle, and it will yield a 45 degree (135 degree) angle.
I agree with you, I don’t think pocket holes would work in that situation.
Split
#8 posted 08-22-2013 07:47 PM
Yes it is exactly what I am trying to do. But I was not sure if I had to leave one as a 90 and one as a 40 to get the 135. Or if I needed to cut the 22.5 on both and put them backwards to each other to get the 45 which is the 135. Does that make sense?
View Earlextech's profile
Earlextech
1162 posts in 2717 days
#9 posted 08-22-2013 08:18 PM
Glue and masking tape as a clamp. Really alot easier than you think. And, pintodeluxe is right, use the same angle on both and you’ll be gluing long grain to long grain.
Split
#10 posted 08-22-2013 08:55 PM
So it would be better to do cut two 22.5 angles and glue than to try a 90 and 45? It is still playing with my head that two 22.5 degree angles makes a 45 and yet is not the same as one 45 degree cut or angle.
Split
#11 posted 08-23-2013 10:17 PM
I got close but I used a stalled drawing and for some reason my middle piece is too big when it should be perfect. Any ideas why?
View Bogeyguy's profile
Bogeyguy
548 posts in 2095 days
#12 posted 08-23-2013 11:12 PM
Hey Split, these guys are the best, huh? :)
-- Art, Pittsburgh.
Split
#13 posted 08-24-2013 06:40 AM
They certainly are I am very appreciative for all the assistance I have received.
Split
#14 posted 08-24-2013 06:41 AM
How did you find the measurements is there a way in sketchup to measure or is there a formula I should use? Thanks
View yrob's profile
yrob
#15 posted 08-25-2013 03:19 AM
You can find it by simple trigonometry. Observing that the triangle that has its hypothenuse (the long diagonal) equal to 17 also has the other 2 sides exactly same length since the angles are 45 degrees, Calling this side a, you get:
a^2+a^2=18^2 using pythagorus theorem. This gives you a=18/sqrt(2) . The side remaining is therefore 24-18/sqrt(2) which is 11 4.35 /16 or as james rounded it, to 11 5/16.. With the diagonal side at 17” you would have needed 24-17/sqrt(2) wihich is very close to 12” (11.98 or 11 63/64”) again, like James previous drawing.
So to sum up, if you build it like that and want a specific diagonal, you can compute the other two dimensions by doing: longside- diagonal/sqrt(2) where longside is 24” in your case (but you can plug in another number there) and diagonal is that diagonal length (17 or 18 in your case). This formula will work as long as you do 135 degrees like in your drawings.
-- Yves
