Router table redesign: need help with dust collection
Forum topic by GerardW posted 08-22-2013 03:28 AM 1878 views 0 times favorited 4 replies Add to Favorites Watch
View GerardW's profile
GerardW
44 posts in 2061 days
08-22-2013 03:28 AM
Topic tags/keywords: router table dust collection shop made
So I’ve had this bench top shop made router table for a couple months now, and I really do like it.
The problem I’ve run into is that now I am getting more diligent about dust collection, using the dust deputy (which I love). The dust port on the back of the fence works well only if I am doing a through cut and don’t totally cover the hole in the fence. When I cover the hole, the suction from the shop vac creates a big drag on my workpiece! And also barely collects the dust, which mostly falls out the bottom.
I have already picked up a nice piece of phenolic faced 3/4 ply, some t track, and a mitre track, with the intention of redoing the top to reduce friction and get a better fit. Any suggestions about changes to the fence or the table body to improve dust collection here? All help is welco,e!
-- Gerard in Bowie MD
View tefinn's profile
tefinn
1222 posts in 2675 days
#1 posted 08-22-2013 03:42 AM
When you completely cover the opening in the fence you lose airflow to the vac. You need airflow for the vac to function. You might try modifying the fence (a split fence in the front with a larger opening on the back fence for the airflow). You might also modify the dust collection attatchment on the back with a wye pipe or a hole drilled into the top to increase the air and reduce the suction on your work piece.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View Joe Lyddon's profile
Joe Lyddon
10369 posts in 4290 days
#2 posted 08-22-2013 08:00 PM
Here is a very cool router table...
He made a Lift… and a Super dust control design…
Get some ideas… Maybe you can use some of them…(??)
Shawn Masterson
1325 posts in 2187 days
#3 posted 08-23-2013 01:27 AM
I would try to space the dust port like 1/2” from the back of the fence.
View gfadvm's profile
gfadvm
14940 posts in 2928 days
#4 posted 08-23-2013 02:45 AM
I would close up the back of your table with some 1/4” ply and add a second dust port near the bottom of the back piece. Any debris the DC misses will be pretty much contained to the space under the table and easy to vacuum out.
