Rivets for bottle opener?
Forum topic by MikeinSC posted 08-21-2013 07:51 PM 1461 views 0 times favorited 9 replies Add to Favorites Watch
View MikeinSC's profile
MikeinSC
63 posts in 2225 days
08-21-2013 07:51 PM
I’m a new woodworker with only 3 cutting boards and loads of saw dust under my belt.
I grabbed this bottle opener the other day that I want to attach some sapele or walnut to for a friend. She was recently promoted to the manager of a beer tasting place.
Would anyone have suggestions on stainless steel rivets to use? Would it be better to make some from SS bolts and epoxy them in? Or is there a SS rivet kit from a woodworking place to buy?
Thanks
-- I am what they call a "rookie".
9 replies so far
View Dallas's profile
Dallas
3599 posts in 2724 days
#1 posted 08-21-2013 08:05 PM
Stainless is really difficult to work with in this case.
Even drilling the holes can cost you a drill bit per hole if you don’t do it correctly, (Low speed and a lot of pressure), and use a coolant.
My suggestion would be to use brass for the rivets. My choice of brass would be one of the brass replacement rods for the toilet float ball.
Good luck.
View crank49's profile
crank49
4032 posts in 3208 days
#2 posted 08-21-2013 08:22 PM
Yes, the brass sounds like an excellent idea,
View PurpLev's profile
PurpLev
8548 posts in 3886 days
#3 posted 08-21-2013 08:36 PM
brass may be easier to work with, but depending on the choice of wood and considering the material of the opener, SS might be the better choice still in terms of looks.
use a centering/stub drill to drill a pilot hole, then finis with the final size drill – use cutting oil/coolant and you should be good to go.
MikeinSC
#4 posted 08-21-2013 11:52 PM
Thank you folks. I picked up the brass rod for a float and some marine grade epoxy for the handle.
Hopefully I won’t screw it up too badly
MikeinSC
#5 posted 08-22-2013 04:00 AM
So far I’ve learned that a drill press would be a necessity for this so that the drill bit doesn’t wander. Even with a punch mark, the bit wanders once it finally starts to cut.
The brass rod looks good paired with the sapele.
View Woodbum's profile
Woodbum
846 posts in 3303 days
#6 posted 08-22-2013 01:19 PM
Check with knife building supply companies. They usually have a wide assortment of rivets and split rivets that have a screw in post and screw setup. A driill press with carbide bits such as a Bad Dog bit are necessary.
-- "Now I'm just another old guy wearing funny clothes"
View lew's profile
lew
12500 posts in 3993 days
#7 posted 08-22-2013 01:44 PM
Although these folks specialize in knife making supplies, I think you might find the rivets you need-
http://www.knifemaking.com/SearchResults.asp?searching=Y&sort=13&search=rivets&show=20&page=2
PurpLev
#8 posted 08-22-2013 01:55 PM
nice find Lew. is that the one you used when you made the kitchen knives?
MikeinSC
#9 posted 08-22-2013 04:38 PM
Thanks for the links. Those are excellent.
Are there any suggestions for a good epoxy? I used a two part marine epoxy from ACE, it’s kinda difficult to spread and to mess with.
