Makita bandsaw
Forum topic by mariva57 posted 08-21-2013 07:26 PM 2891 views 0 times favorited 2 replies Add to Favorites Watch
View mariva57's profile
mariva57
666 posts in 1877 days
08-21-2013 07:26 PM
Topic tags/keywords: bandsaw
I bought a band saw Makita LB 1200 F, I noticed
that the plastic insert is not at the level of the work plan in cast iron, but is below about 4-5/10 of mm, this is normal
difference?
All that I have a problem when I have to cut some small pieces, so I use a tablet of 10 mm MDF
to the plan.
-- The common man thinks. The wise man is silent. The stupid man discusses.
2 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3521 days
#1 posted 08-21-2013 07:34 PM
yes, it is normal on many saws. you definitely don’t want it above the table. you can shim it if you want to level it with the table, or put a secondary surface on the table as a zero clearance work surface like you pictured.
View Surfside's profile
Surfside
3389 posts in 2046 days
#2 posted 08-21-2013 09:18 PM
The table insert is level with the top of the table. “If the insert is too high at the entry side, the job will catch as you push it towards the blade. If the insert is too low it will catch on the table as it leaves the area of the blade. “
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
