What thickness to mill lumber
Forum topic by Slabguy posted 08-20-2013 09:36 PM 1271 views 0 times favorited 10 replies Add to Favorites Watch
View Slabguy's profile
Slabguy
33 posts in 1823 days
08-20-2013 09:36 PM
I plan to start milling some lumber from trees on my property. Should I try to mill a good mixture of 4/4, 6/4, 8/4 etc… or should I mainly stick with one thickness that is useful in most applications? Thanks.
10 replies so far
View Don W's profile
Don W
18791 posts in 2622 days
#1 posted 08-20-2013 09:57 PM
I would cut a mix, but if you’re going to use it, cut what you’ll use.
View Dallas's profile
Dallas
3599 posts in 2542 days
#2 posted 08-20-2013 10:01 PM
I cut what I plan on using then cut as thick as I can on everything else.
My theory is that I can always re-saw but I can’t uncut it.
Good Luck!
View Loco's profile
Loco
210 posts in 1804 days
#3 posted 08-20-2013 10:02 PM
I like to dry mine 2 3/8 or 2 1/2, full width and size them later. These are width sized and dry but not planed-sanded yet.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
View WDHLT15's profile
WDHLT15
1755 posts in 2531 days
#4 posted 08-21-2013 01:42 AM
A mix for sure.
Shawn Masterson
1325 posts in 2003 days
#5 posted 08-21-2013 02:14 AM
one thing to remember is the thicker you cut it the longer it takes to dry.
View rustfever's profile
rustfever
753 posts in 3365 days
#6 posted 08-21-2013 02:51 AM
When re sawing thick lumber, you must be sure it is dry consistently, all the way thru. If not, the re-sawn face may be wetter than the other, and it will dry like a pretzel. Now you have two worthless boards!
Been there, done that!
-- Rustfever, Central California
View pintodeluxe's profile
pintodeluxe
5726 posts in 2868 days
#7 posted 08-21-2013 05:03 AM
I would mill half at 4/4, and the rest split between 5/4 and 8/4.
5/4 makes great tabletops. 8/4 will make curved chair rails, as well as leg stock.
4/4 can make everything else.
good luck with it!
View Loco's profile
Loco
#8 posted 08-21-2013 07:07 AM
Slow drying results in less checks,depending on the woods density and oil content, of course.
Slabguy
#9 posted 08-21-2013 01:05 PM
Thanks for the help guys. All good answers
View grizzlymunchin's profile
grizzlymunchin
47 posts in 1798 days
#10 posted 08-21-2013 01:50 PM
cutting at 5/4 will enable you to get good straight lumber if its cupped or bowed a little I learned this the hard way
-- woodshop by the cornfeild
