Metal insert
Forum topic by coachmancuso posted 08-20-2013 12:34 PM 925 views 0 times favorited 6 replies Add to Favorites Watch
View coachmancuso's profile
coachmancuso
259 posts in 1932 days
08-20-2013 12:34 PM
I have a metal insert that was in a wooden leg to a table that had stripped out of the wood what is the best way to get it back in there to stay? It is in pine. The wooden insert is a anchor that goes into the wood to put the lag bolt into it to hold the leg on.
-- Coach Mancuso
View Rex B's profile
Rex B
320 posts in 2251 days
#1 posted 08-20-2013 01:15 PM
Does the insert look something like this?
If it’s not stripped out too bad I would probably just try to glue it in with epoxy. If the wood is torn up pretty bad a better fix may be to drill out a large hole with a forstner bit and plug it with a piece of hardwood, then re-drill for the insert.
-- Rex
coachmancuso
#2 posted 08-20-2013 01:58 PM
yes it does look like the picture. 2 Part epoxy?
-- Coach Mancuso
Rex B
#3 posted 08-20-2013 02:01 PM
Yeah, any ol’ 5 minute epoxy should do fine, something like this for example.
-- Rex
coachmancuso
#4 posted 08-20-2013 02:14 PM
Thanks Rex
-- Coach Mancuso
View MrRon's profile
MrRon
4771 posts in 3244 days
#5 posted 08-20-2013 05:49 PM
”I second the second half of what Rex said….plug it…fix it right, epoxy is just a bandaid.”
Ditto that.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2073 days
#6 posted 08-20-2013 10:09 PM
I third the plug it, re drill method, usually with mahogany or oak plugs I keep cut around the shop.
-- Who is John Galt?
