HF 2HP Dust Collector Band "Spring" Clamps
Forum topic by tengallonhat posted 08-19-2013 08:06 PM 1392 views 0 times favorited 5 replies Add to Favorites Watch
View tengallonhat's profile
tengallonhat
79 posts in 1664 days
08-19-2013 08:06 PM
Topic tags/keywords: question resource tip
The HF Dust Collector comes with two spring style band clamps (5” in diameter). I am connecting it up to pre-seperator and need one more 5” clamp. I can’t seem to source a 5” band clamp like this online or at Rockler, Woodcraft, HF, etc… Does anyone know where I can get one of these? Or perhaps suggest an alternative?
I’m doing something very similar to this mod I found here on this site.
5 replies so far
View gtbuzz's profile
gtbuzz
427 posts in 2350 days
#1 posted 08-19-2013 08:16 PM
You could always use a regular hose clamp. They’re readily available at Home Depot in that size for like $2. I prefer to use bridge clamps myself as they go over the spiral, but they’re quite hard to find in > 4”. I get mine from McMaster-Carr. They’re a little pricey though, about $6-$7 in that size. They’re a little cheaper at Wynn Environmental , but I have a McMaster-Carr warehouse near me, so I can avoid shipping. If you’ve got to get it shipped either way, give Dick Wynn a call. They’re some great people there.
View dbhost's profile
dbhost
5686 posts in 3141 days
#2 posted 08-19-2013 08:23 PM
Are you talking about the wire hose clamps that hold the flex hose from the impeller housing to the ring? You can order those from Kencraft http://www.kencraftstore.com/wirehoseclamp.htm
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
tengallonhat
#3 posted 08-20-2013 04:08 PM
Thanks. I overlooked the little bins at Home Depot. I went back and found the 5” hose clamps got home only to realize they are still to small to fit on the bit of hose that comes with the dust collector. I am headed back today to pick up 6” hose clamps.
View Matt Przybylski's profile
Matt Przybylski
539 posts in 2287 days
#4 posted 08-20-2013 04:40 PM
You could also just use a long zip tie for one of the connections which doesn’t need to get disconnected regularly.
-- Matt, Arizona, http://www.reintroducing.com
gtbuzz
#5 posted 08-20-2013 05:17 PM
One thing about the regular hose clamps and those wire hose clamps – I find they don’t always seal as well as the bridge clamps. Keep an eye on the joint and see if you’ve got any stray dust coming out. If you do, you can always try clamping a little harder, or you could just caulk around the joint if you don’t plan on taking it apart. I didn’t want to go that route and I just wrapped a bunch of painter’s tape around it and it worked well for me.
