6" Boice & Crane Jointer
Forum topic by Boodles posted 08-19-2013 04:03 PM 10185 views 0 times favorited 36 replies Add to Favorites Watch
View Boodles's profile
Boodles
31 posts in 1782 days
08-19-2013 04:03 PM
Hello Everyone!
As usual, I’m on CL teasing myself looking at used tools, and I found this 6” Boice & Crane Jointer for $80. I just called the guy and he said his friend did some work on it and restored it, and that it works well…
Also, what is the price range for a 6” jointer from a “good” brand that will serve my limited needs to a while (brand new to woodworking, and so far have some hand tools and a TS).
Boice & Crane – http://orangecounty.craigslist.org/tls/4007028879.html
Or, would a C-man be better for around $100ish?
Any thoughts?
Thanks!
36 replies so far
View b2rtch's profile
b2rtch
4861 posts in 3072 days
#1 posted 08-19-2013 04:07 PM
In general I recommend to not buy a 6” joiner as you will out grow it almost immediately.
I recommend to skip the 6” and to buy at least a 8” jointer, 10” being even better.
-- Bert
View Loren's profile
10476 posts in 3672 days
#2 posted 08-19-2013 04:37 PM
6” is fine for most work in my experience. You have
to start somewhere. Used 8” jointers sell in So. Cal
for $350 and up so you could certainly hold out if
you wanted to.
That Boice Crane has been for sale for awhile. It
looks like it is set up with a nice catch box for
chips, which is something you won’t usually get.
Also, see that big ledge? It can be used to support
boards when surface jointing stock wider than 6”.
Boodles
#3 posted 08-19-2013 04:49 PM
Thanks for the replies… I don’t plan on doing much more than small things (boxes, small bedside tables, etc) for a few years (being a full time student and all), so I think that 6” will be adequate.
Loren, would this be a good buy for $80, or should I keep looking/wait?
18351 posts in 1880 days
#4 posted 08-19-2013 04:51 PM
The most jointing I do is edge joiinting so it doesn’t matter how wide it is. What mattered for me was the length of the table. I wanted to be able to joint longer boards so I got the 6 with a 46” table. If I need to flatten a real wide board I’ll use my thickness planer with a jig. I think that voice would be worth a try for maybe 60 or 70.
View waho6o9's profile
waho6o9
8207 posts in 2601 days
#5 posted 08-19-2013 04:52 PM
That big ledge can also be used to make tenons as well.
Good eye Loren.
#6 posted 08-19-2013 04:52 PM
Oh that’s a good deal, especially considering the
guard is there and it’s all set up and running right.
You certainly won’t get hurt at that price.
View shampeon's profile
shampeon
1775 posts in 2207 days
#7 posted 08-19-2013 04:54 PM
$80 for a working Boice-Crane jointer with stand, motor, and catch box is a very good deal, IMO. These were well-made machines.
Boodles
#8 posted 08-19-2013 05:23 PM
So I’ve been doing a bit more research on jointers.. and I have uncovered a hotly debated topic – buy a jointer or planer first?
Any input?
Also, thanks for all the responses, guys!
#9 posted 08-19-2013 05:51 PM
I’ve had a planer for 15 years. Jointer for 1. They go well togethr, but I think if you’re gonna have one it has to be the planer. If you want particular thickness of stock you need the planer. You can do some jointing with the planer with a jig.
#10 posted 08-19-2013 06:02 PM
You can do a lot with a jointer, band saw and hand planes.
Affordable benchtop planers have really changed the
way hobbiests can invest in machinery. Planers
used to be really substantial investments. Say
you wanted to make a table – you’d flatten and
thickness the board by hand and do the edges
on the jointer. Then you’d do the top and bottom
with hand planes after it was glued up. For the
square legs you would joint two adjoining faces so they
were square and straight, then band saw
parallel the other two faces which you could then
clean up with the jointer without losing dimensional
consistency.
You really want both for working in solid wood. With
planers being so affordable now it’s not so hard
to get both. For the price of a used 8” jointer
you could get a 6” and a planer.
Boodles
#11 posted 08-19-2013 06:57 PM
Perfect, thanks guys!! Turns out I can get a C-man Model # 351.217880 of CL for $100 (maybe less if I negotiate).. it’s a much newer machine, and parts are readily available (it was released in 2002).
How would a machine like this compare to the Boice-Crane? It’s still a 6” jointer..
Thank you all for your patience!
View MrUnix's profile
MrUnix
6766 posts in 2223 days
#12 posted 08-19-2013 07:52 PM
$80 for that jointer is a great deal.. those BC jointers are built like a tank and will last forever. Knives are readily available and standard, as are the cutter head bearings. Everything else is cast iron or standard hardware store stuff, so you most likely will never need anything else for it. It is also fairly unique in that it has a full length fence and a fence lock on the both ends, so once you lock it down, it stays put and doesn’t flex regardless of how much pressure is put on it. I’d take the BC over a craftsman any day (and did). I picked up mine in much rougher shape for $85 (although it did have the original factory stand) and did the restore myself. It’s been a joy to use ever since. Here is a picture of mine after the restore:
shampeon
#13 posted 08-19-2013 07:56 PM
That Craftsman is a benchtop light-duty hobbyist toy. The B-C is much heavier duty. A wrench from the dollar store and a forged Snap-On wrench are both wrenches, right?
View tefinn's profile
tefinn
1222 posts in 2461 days
#14 posted 08-19-2013 08:02 PM
I’ve restored a couple of Boice-Crane jointers. The Craftsman can’t compare to them! The 351 model C-man is a bench top model with lots of plastic and aluminum parts. It has a short bed and low hp. The Boice-Crane is all cast iron and a longer bed. The hp is only limited to the size of the motor you put on it. The one on CL looks like a 1400 series made from late 30’s to early 50’s.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
waho6o9
#15 posted 08-19-2013 08:04 PM
Beautiful restore Brad, good job.
showing 1 through 15 of 36 replies
