Accuracy in planing lumber
Forum topic by oldwoodsale posted 08-18-2013 11:59 PM 1012 views 0 times favorited 5 replies Add to Favorites Watch
View oldwoodsale's profile
oldwoodsale
21 posts in 2845 days
08-18-2013 11:59 PM
Topic tags/keywords: planer accuracy grizzly
I just got a new Grizzly 15” planer and was wondering what kind of accuracy I should expect from the unit. I put a digital gauge on the unit and I am not using the standard pointer. When I set the gauge for a thin pass like under .050 I am off by only a few thousands. If I take thicker passes above .050 and with wider boards I am off by .010. I can run it through again, but I have to reset the planer. What I mean by this is I have to unlock the bed crank it down a bit and then back to my original measurement. There seems to be flex in the planer bed caused by thicker cuts. Anyone else have this issue or should I be happy the this performance.
5 replies so far
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2226 days
#1 posted 08-19-2013 05:11 AM
most of their machines should have around a 5-7 thousandths accuracy, in this case though you should be able to do a 1/8th inch pass without any flex, if not, then something is loose in the bed and may need tightening, in which case you need someone more experienced with the particular machine to tell you what you need to adjust, as this one is not exactly one I’ve used before.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
9763 posts in 3519 days
#2 posted 08-19-2013 05:27 AM
Check thickness at several points in the board. Variations
at frame corners are a bugaboo in pro cabinet work. If the
whole job is run through at once, then it’s the consistency
from part to part that matters more than repeatability on
the scale.
View unbob's profile
unbob
801 posts in 1774 days
#3 posted 08-19-2013 06:36 AM
Problems with any material cutting machines show up on light verses heavy cuts.
Due to machine/work deflection, a critical finish size is best approached in at least two cuts. First a roughing cut, then a lighter finish cut.
The depth of those cuts would vary due to the machine, and material being cut. The condition of the cutters is a factor also.
View fredj's profile
fredj
186 posts in 1689 days
#4 posted 08-19-2013 01:18 PM
All above is good advise. The flex may be due to the feed rollers or pressure bar. I don’t know your machine, but have seen that issue in other planers. Take a few pieces of the same wood that you know are the same thickness. Run one on the far left of the bed, one on the far right and compare. I tend not to trust gages and pointers and go by measurement of what comes out of the planer. It’s also a good idea to work you way back and worth across the width of the bed to ensure even wear of the cutters.
-- Fredj
View mantwi's profile
mantwi
312 posts in 1767 days
#5 posted 08-19-2013 01:46 PM
I’d look at the bed rollers. I always lower them to flush with the bed and wax the bed to insure a smooth feed. The recommended bed roller height range is between .002 and .020 in my 20” planers manual, that’s a pretty wide range for the factory tech to shoot at and at the upper end flex in the board between the rollers would account for the problem. The cutter head is exerting a lot of pressure on the material. Removing the rollers from the equation should eliminate the issue.
