Auto adjust planer tables
Forum topic by oldwoodsale posted 08-18-2013 02:08 AM 868 views 0 times favorited 2 replies Add to Favorites Watch
View oldwoodsale's profile
oldwoodsale
21 posts in 2972 days
08-18-2013 02:08 AM
Thought you might like to see my auto adjusting planer in/out tables. I plane 13’ long oak boards that can weigh 100+ lb. Lifting these all day around the planer will wear you out real quick. So this is my first attempt at making a set of adjusting conveyor tables. They still need a bit of adjusting but I got the concept down. So at this point I’m fairly confident they will work. Video below.
http://www.youtube.com/watch?v=1nguP6nmbUc&feature=youtu.be
2 replies so far
View Loren's profile
10394 posts in 3646 days
#1 posted 08-18-2013 02:27 AM
Pretty cool. What is the switch type called?
oldwoodsale
#2 posted 08-18-2013 02:34 AM
Loren, they are called micro switches. Its your choice how it works. It can be normally closed or open. Then when the little roller is pushed it will change its state from open to closed or vice versa. You can get many different versions of them.
