Table saw blade won't spin
Forum topic by tazboy posted 08-17-2013 11:02 PM 12508 views 0 times favorited 23 replies Add to Favorites Watch
View tazboy's profile
tazboy
30 posts in 1734 days
08-17-2013 11:02 PM
When I turn on the table saw I get a humming sound from the motor. I also get a ticking sound which I believe is from the relay. The blade spins freely, by hand, when it’s off, but it won’t spin after I turn it on (haven’t tried it by hand when it’s on). The capacitor is not swollen nor is there any leakage coming from it. What could be causing the table saw not to work properly?
Thanks
EDIT:
This is a Rockwell 9” 34-580 table saw.
23 replies so far
View Bill Davis's profile
Bill Davis
226 posts in 3889 days
#1 posted 08-17-2013 11:15 PM
My best guess is the capacitor. They don’t have to be swollen or leaking. They are not that expensive. Just replace the one you’ve got and try it. Or pull the motor and take it into a motor repair shop.
View cutmantom's profile
cutmantom
402 posts in 3000 days
#2 posted 08-17-2013 11:21 PM
Could be the centifugal switch
View tefinn's profile
tefinn
1222 posts in 2402 days
#3 posted 08-17-2013 11:23 PM
+1 on what Bill said. It might also be the centrifugal switch in the end of the motor. Try blowing out the motor, sometimes sawdust builds up in the switch.
Edit: Cutmantom posted while I was typing
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
TopamaxSurvivor
18246 posts in 3641 days
#4 posted 08-17-2013 11:28 PM
If it is the cap, it should go if you give it a spin by hand. If it is the centrifugal switch, you might whack the motor on the end with a mallet. It may go and maybe not.
Shawn Masterson
1325 posts in 1914 days
#5 posted 08-18-2013 01:01 AM
spin it and then turn it on while it is still spinning.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2320 days
#6 posted 08-18-2013 01:24 AM
1. What kind of saw is this?
2. My contractor saw is broken at the moment, it does the same thing, motor is fine, but the gears that drive the blade are, shattered… May be a similiar problem.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Marcus's profile
Marcus
1163 posts in 1985 days
#7 posted 08-18-2013 01:25 AM
Another vote for a dead cap .
TCCcabinetmaker
#8 posted 08-18-2013 01:27 AM
Not enough information to go off of to say what the problem is, you can say this or that, but without knowing what it is, how it’s driven, we don’t know, could be a broken belt… Motors hum when they are on.
View grizzlymunchin's profile
grizzlymunchin
47 posts in 1708 days
#9 posted 08-18-2013 01:42 AM
if your bearings are bad the motor will hum sometimes, can you spin the blade freely very easy or is it hard if the bearings are bad the blade will lock and unlock sometimes take the belt off and see what happens
-- woodshop by the cornfeild
grizzlymunchin
#10 posted 08-18-2013 01:44 AM
thats how I found out my bearings were bad at first I thought I burnt the motor but it was just the bearings so take the belt off and make sure it’s the motor
tazboy
#11 posted 08-18-2013 01:06 PM
Ok. So I went down and started the table saw. It actually started spinning by itself. Unfortunately, it spun very slowly. I applied a small resistance to the blade, it stopped and then it wouldn’t spin back up even if I helped it spin. Also, there was a burning smell. I’m guessing that rules out the capacitor. Could it still be the centrifugal switch?
grizzlymunchin
#12 posted 08-18-2013 06:01 PM
sounds like bearings are cold that means it will start till they get hot and swell then the saw locks up have you taken the belt off yet and tried the motor by itself?
TCCcabinetmaker
#13 posted 08-18-2013 07:19 PM
You do realize that though people sound like they know exactly what’s wrong with your table saw, your table saw may not even have the parts they are talking about…..
Table saws are not made the same way, some are gear driven, some are belt driven….. INFORMATION is needed to help diagnose your table saw, and from what you are saying it would be best before you burn out the motor, if that’s not just the brushes going out as well….
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3550 days
#14 posted 08-18-2013 07:29 PM
Why not get someone who knows about these things and can be trusted these days sadly not to screw you because of your ignorance of the problem (such people are only too frequent these days sorry but it’s true) then play it by ear or better still contact the manufacturters of the saw for advice. Alistair
View papadan's profile
papadan
3584 posts in 3334 days
#15 posted 08-18-2013 07:40 PM
Lots of advice here, but none I would listen to because the most important has not been mentioned. DON’T TRY SPINNING THE BLADE WITH THE SAW TURNED ON OR EVEN PLUGGED IN! Your fingers are worth more than that. Pull the plug then remove the belt. Now figure out if it is bearing or capacitor or what ever.
