Tapping Wood????
Forum topic by HillWilly posted 08-17-2013 12:40 PM 1041 views 0 times favorited 5 replies Add to Favorites Watch
View HillWilly's profile
HillWilly
54 posts in 2307 days
08-17-2013 12:40 PM
I was just reading a review by DeLayne Peck of a drill/tap and wanted to pass this on. There are two types of taps. Cut taps and Form taps. The cut tap function is obvious but the form tap re-forms the metal [or in this case wood] to make threads. There is something called percentage of thread or ”POT” where the POT is increased when a smaller pilot hole is drilled. Me thinks that some research on drill and tap sizes and some experimention with CA glues or wood hardener [as mentioned in DeLaynes review responses] acceptable thread strength could be achieved even in soft woods, MAYBE!!!!! Let me know.
-- ...and whether or not it is clear to us, no doubt the universe is unfolding as it should...DESIDERATA...Max Ehrmann
5 replies so far
View NiteWalker's profile
NiteWalker
2738 posts in 2775 days
#1 posted 08-17-2013 01:42 PM
I never put much thought into it; I just bought the tap set from lowe’s and got to it.
I do use a slightly smaller drill for more thread engagement.
The thin CA glue I use is the titebond brand.
View MrRon's profile
MrRon
5190 posts in 3442 days
#2 posted 08-17-2013 09:47 PM
I have tapped hardwood successfully. I haven’t tried soft woods.. I usually use threaded inserts for soft woods.
MrRon
#3 posted 08-18-2013 04:33 PM
I have found a real useful use for threading wood. When I make a new insert plate for my table saw, I drill and tap 4 holes for 8-32 set screws to level the plate. I use one size smaller tap drill to ensure a tight fit that will stay put.
HillWilly
#4 posted 08-19-2013 01:35 PM
I like yer comment MrRon. When I recieved my dads saw it came with a hand made aluminum insert that doesn’t fit really well and rattles like crazy. I think I’m gonna do a nice hardboard zero clearance insert with adjusters like yers.
NiteWalker
#5 posted 08-19-2013 02:28 PM
I do the same with my zci’s.
Much easier to level than the hot glue method or trying to plane the zci to the right thickness.
