Crown Molding
Forum topic by DennisD posted 08-17-2013 01:13 AM 1275 views 0 times favorited 3 replies Add to Favorites Watch
View DennisD's profile
DennisD
28 posts in 3213 days
08-17-2013 01:13 AM
Topic tags/keywords: crown molding attaching tip
I have made a wall bookcase and it calls for crown molding for the top. I made oak cove 3” molding to attach to the top. My question is which size pins to use to attach to the base cabinet. I have a 23 gauge, 16 gauge, 18 gauge nail gun. Will glue with molding glue. One straight board 36” and two box type cabinets 17X24.
Thanks
Dennis
-- Dennis,Houston,
3 replies so far
View DGD47's profile
DGD47
1 post in 1742 days
#1 posted 08-17-2013 01:26 AM
I was in the same situation as you, I used 23 gauge with glue so I don’t have to fill the holes. It held up just fine.
View Loren's profile
9964 posts in 3555 days
#2 posted 08-17-2013 02:37 AM
Sometimes the corners can be tricky to close. Use the
fine pins if they will pull the moulding in tight, but in
some places it may not. I clamp corners with special
“spring pinch clamps”. I think Lee Valley sells an
inexpensive version.
http://www.leevalley.com/en/wood/page.aspx?cat=1,43838&p=54189
Garret Wade too:
http://www.garrettwade.com/special-spring-mitre-clamps/p/05D02.04/
Mine are like an Ulmia knockoff but they may not be something
you can buy anymore.
If the work is to be painted, you can be a sinner in
terms of your miter clamping and nobody but you
will know.
DennisD
#3 posted 08-17-2013 02:57 AM
Thanks. I have the spring clamps which I use to assist with picture frames.
-- Dennis,Houston,
