Lenox bandsaw blade?
Forum topic by mski posted 11-12-2008 01:10 AM 1002 views 0 times favorited 2 replies Add to Favorites Watch
View mski's profile
mski
439 posts in 3950 days
11-12-2008 01:10 AM
I just got a USA Delta 14” bandsaw on Craigslist, $200, after quickly setting the guides per the bandsaw book by Bird it run smooth and tracked straight (set a nickle on the table and it stood up for quite awhile)
I am installing a riser block, it came with a carter high tension spring. Also He said it had a Woodslicer blade, it cut a 5 1/2” piece of 1/4 sawn white oak with ease but the cut had alot of ridges, not real deep , I could live with them.
After I add the riser I need longer blades and if the carbide blade will cut better AND last longer for the $ I would invest.
Has any Jock used a Lenox 1/2” Trimaster carbide blade with this saw and would the saw tension it properly?
I searched but only could find topics on larger saws.
Thanks
-- MARK IN BOB, So. CAL
2 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3682 days
#1 posted 02-01-2009 07:44 AM
Mark, did you ever resolve this?
View mski's profile
mski
#2 posted 02-01-2009 04:05 PM
Yes, I found one for $75 at my sharpening shop that someone returned, it was like new.
The saw tensions it fine ,I have a high tension spring, the blade will cut through anything but does leave a faily rough cut.
