A question about cutting Kerfs on Box Joint, Box joinery?
Forum topic by Blackie_ posted 08-15-2013 10:09 PM 1766 views 0 times favorited 8 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2513 days
08-15-2013 10:09 PM
I have a question on finger joint, box joint and dovetail joinery when it comes to cutting the kerfs on the inside side walls for the bottom’s and the lids how is this done?
I have miter joinery down and figured out but after completed my first box joint joinery box and after cutting the bottom kerf for the bottom panel, I went through the box joints exposing the inner of the box lucky I was able to hide the mistakes with square pegs cut to fit the 1/4” square holes left in the side of the box on all 4 corners.
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
8 replies so far
View MrFid's profile
MrFid
874 posts in 1905 days
#1 posted 08-15-2013 10:18 PM
I was trying to come up with a solution to this recently as well. From what I see, you have two options:
1. Cut your kerf for the bottom and lid with a router table with stop blocks positioned such that the bit won’t get all the way through the finger, or
2. Your solution.
Personally, I prefer the router table route, as I think it’s a cleaner look not to have to worry about plugs.
With plugs, you have two options:
1. Use matching wood with matching grain orientation with the hope of making the plug unnoticeable, or
2. Use a contrasting wood and highlight the fact that you used plugs a la Greene and Greene style sort of a thing. Use them as a design feature.
Maybe there are better ways which someone has come up with, but these are the two I have used in the past. Good luck, I’ll be watching this thread in case someone is smarter than me (generally, most people seem to be).
-- Bailey F - Eastern Mass.
Blackie_
#2 posted 08-15-2013 10:41 PM
Thanks Bailey
OK so using stop blocks means I’d have to position the work starting point at the up spiral bit and then press into it then move piece making sure I stop before exiting the finger.
MrFid
#3 posted 08-15-2013 11:00 PM
Yeah. What you’re basically doing is cutting a really long mortise. Here a good page with some decent illustrations.
You want two stop blocks positioned so that the bit enters and exits the wood at the correct locations.
View littlecope's profile
littlecope
3071 posts in 3503 days
#4 posted 08-15-2013 11:00 PM
I’ve always just blocked up the exposures like you did Randy until recently, when I started mitering the top and bottom of each joint…Two more corners to fit...
I want to try the router method that Bailey mentioned sometime… It’s my understanding that you drill shallow holes on either end of the dado, so you don’t have to plunge the piece onto the router… I think that would help on setting the router fence too!
Blackie_
#5 posted 08-15-2013 11:07 PM
Bailey that link was broken
View gfadvm's profile
gfadvm
14940 posts in 2691 days
#6 posted 08-16-2013 01:22 AM
I use the router table and 2 stop blocks method. I usually make 2 passes rather than extending the bit to achieve the final depth in 1 pass. This makes it easier to control.
I bought some odd sized spiral bits to accommodate the different plywood thickness from Grizzly and really like them.
MrFid
#7 posted 08-16-2013 01:23 AM
http://www.woodworkingtips.com/etips/2005/06/24/wb/
See if that one works.
Blackie_
#8 posted 08-16-2013 01:46 AM
Mike, I like your method, I currently am using my router table for all of my kerf’s don’t like much swapping on tablesaw blades,
Andy makes perfect since thanks.
New link works Bailey thanks.
